Sponsored by: Real Truck
Drive shaft help
Old Aug 4, 2010 | 07:03 PM
aceltx09's Avatar
aceltx09
Drive shaft help
I'm replacing all my u-joints and carrier bearing,95k on them, I keep reading about marking the drive shaft before removing. Can anybody shed some light on exactly what I should be doing. Please be specific if possible I'm mechanical, but not familiar with all names of parts. Thanks
Old Aug 4, 2010 | 08:29 PM
ak-angler's Avatar
ak-angler
You want to make sure you put all the pieces back together the same way they came apart. To make sure that happens, put alignment marks on each side of the u-joint yokes, the slip yokes, the tranny output shaft, and the diff input shaft. And if you're going to have it all apart at once, you might want to mark which end of the main shaft goes forward, so it doesn't inadvertently get flipped end for end.
wavetrain75
Mar 25, 2014 07:16 PM
67F250RET
Mar 28, 2013 03:21 PM
coreymck
Oct 29, 2012 11:03 PM
drunkdave
1978 - 1996 Big Bronco
Sep 17, 2009 12:40 PM
tomoto
Jan 21, 2006 07:59 PM
