Crank machining
Old Aug 24, 2015 | 06:33 AM
MtTheJeffro's Avatar
MtTheJeffro
Crank machining
Haven't talked to my machinist yet, but looking for some opinions based off of your experience and my build expectations. I'm going to have to get my crank turned, but I'm not going nuts with my build so I'm wondering how much is too much?
93 IDIT block
88 N/A pistons and rods
R&D cam
93 stock turbo
3" downpipe to 4" exhaust
Headstuds just because
I see bearing kits up to .030 over. Is that taking off too much for what I'm pushing? I value your opinions and experience over any machinists'.
Thanks.
Old Aug 24, 2015 | 06:43 AM
stuart1's Avatar
stuart1
Measure the crank first. It may just need polishing.
.030 undersize bearings are very close to max.
Old Aug 24, 2015 | 07:08 AM
MtTheJeffro
It's got some nasty heat rings and a few minor grooves. It's gonna need some real love. Thanks
Old Aug 24, 2015 | 07:10 AM
MtTheJeffro
Old Aug 25, 2015 | 08:52 PM
PlumCrazy7's Avatar
PlumCrazy7
Definitely don't go in asking to take 30 off. Have the machinist work up from 10 and 20. It's impossible to tell in pics but my old man (master mechanic) said if you can feel a groove (scuff) with your fingernail its at least a few thousandths. I don't know how deep yours feels but that's a ballpark to give you a better idea.
Old Aug 25, 2015 | 09:37 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Just take it in and ask em to clean it up. If you want to know what the factory spec is look it up and tell him that number. Should be something like .002
Old Aug 26, 2015 | 06:13 AM
MtTheJeffro
Thanks for the replies. Lol obviously take off as little as possible etc. what I'm trying to figure out is if I wind up taking .0030 off, am I running "too weak" of a crank for my build?
(This is the part where I'd love someone to chime in and say they're running a 350hp beast and they took 30 off without any issues...lol)
Old Aug 26, 2015 | 08:33 AM
dropitlow88's Avatar
dropitlow88
Always this option. not sure of cost. IDI cranks from rockauto.com run $319 plus shipping and a $200 core. Crankshaft Welding
Old Aug 26, 2015 | 06:41 PM
hairyboxnoogle
Wow. pics didnt load last night, if i were in your shoes i would be looking for a new crank. Those gouges in the top pic arent coming out.
Old Aug 26, 2015 | 07:24 PM
MtTheJeffro
Lol yea, hence the worry about machining
I have the N/A motor I'm pulling from truck shortly. I was gonna compare the two and hope for good news. Sadly that one has a rod knock so I'm not expecting it to look too wonderful either.
I hope scrap prices are up right now....
Old Aug 27, 2015 | 10:11 PM
Macrobb's Avatar
Macrobb
Eh, might be just fine. Mine knocked badly; parts were spotless inside. The bearings were quite worn, rings totally shot, but all the steel was great.
Old Aug 30, 2015 | 02:48 PM
hairyboxnoogle
What Mac said. The nailhead in my buick was knocking, crank was perfect. Reconditioned a couple rods and put some bearings in it and was good to go.
Old Sep 1, 2015 | 09:08 AM
RacinNdrummin's Avatar
RacinNdrummin
Keep in mind that the Journals are hardened, so grinding the crank will take that layer away.
Seems like a good candidate for the fingernail test... If you can hook a fingernail on any of the grooves, it probably needs to be ground, If not, I would plastigauge to check clearance, and put it back together.
Old Sep 1, 2015 | 09:36 AM
MtTheJeffro
hahaha...definitely not passing the fingernail test. Definitely needs some attention, i'm just concerned about grinding too much off. I'm just starting to take apart the truck now so i'll have another crank to look at once the motor is apart.
Hi Justin, check and core cam are in the mail
HAMS64
Jul 25, 2017 01:16 PM
3twinridges
Nov 8, 2016 10:56 AM
crazy96863
41
Nov 27, 2012 07:34 AM
maribou912
23
Jul 9, 2012 11:37 PM
Rancha9
22
Mar 28, 2005 11:32 AM
