460 CRANK PULLED OUT
Old Jul 24, 2017 | 07:52 PM
HAMS64's Avatar
HAMS64
I have pulled the 460 out of my 64 F100, flipped it over and pulled the crank out of it. I know that the engine is around a '73 out of a Lincoln. How many miles, I am not sure. I pulled the engine due to upwards play in the crank. SO I pulled it out and this is what I saw...a few pics.....i have questions....I also have a friend stopping by to look things over, for he is more familiar with the internals than me.
front main bearing
rear main bearing
front main cap
most all rod bearings look like this
-I would say this may be typical with a engine that may have, not sure, 100..200,000 miles on it?
-How much to have a machine shop rework the crank? (to me it looks like it is in pretty good shape)
--So many different types of cranks, materials and what not, for a replacement, anything to stay away from?(I am not looking to build this 460, just keep it basically stock)
-- In the next pic you can see that one of the push rods are of a different color. Could it be it has been replaced at one time or another? Makes me think it got hot?
top of the rod seems colored.
I am a bit lost as to what I may do. If i slap a crank in it and go, what next? SO I am really thinking hard about going with something different in a engine. May be a CV conversion, or maybe a 302. Not sure but like to hear what you all have to say about what you see.
Thanks as always,
Hammy
Old Jul 24, 2017 | 09:19 PM
thrifty's Avatar
thrifty
If it were me I would check the line bore. Slapping a crank in may not cure your problems, or maybe it would for a short time? Is the crank ok, does it need to be turned ect. ect. I would check the crank and see if it is egg shaped. Do the cylinders need to be bored? The rod may have gotten hot. The list can go on. How much do you want to spend? Or get another motor? All depends on your intentions
Old Jul 25, 2017 | 11:19 AM
HAMS64's Avatar
HAMS64
THRIFTY...
Thanks for the comments. This is the kind of thing I am looking for. How would others move forward. Yes, it seems that I am this far into it, why would I drop a new or machined crank back into it without breaking down the complete engine, machine it all and put back together. It comes down to logistics, if you will, moneys.
I have a local engine builder but most I talk to spend crazy moneys for a mild build. I could get a new short block, a bit more reasonable if I stay within a "stock" build. I could buy another used engine, but then back to the same issues.
Thanks, look forward to other comments....Hammy
Old Jul 25, 2017 | 12:05 PM
RacerJames's Avatar
RacerJames
Well, It looks like sometime in the life of that engine that someone ran it out of oil.
Where I live, an '03 and newer Crown Vic at auction will cost between 800 and 1200.00, which is the cost of rebuilding your 460. then you have all the time and trouble swapping the front end, hooking up steering, cutting and welding brackets and things to make the CV stuff fit your truck.
So, it boils down to whether you want the same as you've got now, only repaired, for around 1200.00, and 10 to 15 hours labor -
Or, you can have 4 wheel disc brakes, power rack and pinion, positraction rear diff (most cop cars came with them) Fuel injection, and a lowered, highly modified truck which behaves like a cop car for around 1200.00 and 60 to 100 hours of blood sweat and tears.
Old Jul 25, 2017 | 12:18 PM
HAMS64's Avatar
HAMS64
Hey Racerjames...thanks for your comments..
It may be that someone ran it low...I have had the truck for about 3 years now but haven't drove it enough to see if the oil drops. Didn't seem to be burning it.
You think 1200 and or about that to rebuild the engine? Is that having the machining done and reassembly myself? I would think so.?
Then I have the burden of it being assembled right, which I have the abilities to do so and or the best I can. You only get one chance with a engine. I ask this for some of the guys I talked to in the area say they are putting 5 to 6 grand in a rebuilt engine. Yea I think some are modified, but I sure didnt want to go that far specially if I keep the straight axle...
Yea CV is calling me to be honest...BUT I so love the "looks" of the straight axle..handling is another issue. But I wouldn't do a CV with out the front end, engine, trans, rear end.
Thanks
Hammy
Old Jul 25, 2017 | 12:37 PM
RacerJames's Avatar
RacerJames
My engine builder would do all the necessary machine work for around 600 to 700.00 - that includes turning and polishing the crank. An engine kit from my usual supplier ( https://www.northernautoparts.com/part/ek-ek0578 ) is 370.00 plus whatever upgraded parts you want.
So, that 460 could be machined at my machinist's place, and rebuilt in my garage for between 970 and 1200.00. I am an ASE certified master mechanic, so this kind of thing is right in my wheelhouse.
My advice to you and all hobbyists (including me) is: trust yourself, and carefully follow all the procedures the part manufacturer or Motor or Chilton (or if you've got one - Manufacturer's) shop manual recommends, and you'll rarely if ever have a failure.
This is how I became certifiable
Old Jul 25, 2017 | 01:16 PM
HAMS64's Avatar
HAMS64
Thanks so much Racerjames.......You busy? Want to build it for me? Opps, your a long way away.
I built a 302 back about 10 years ago. All the machining and rebuild kit was already purchased, I bought it and all I did was build it, and it held up fine. I agree, attention to detail, clean room, reading materials, time, OH and patience...
Again thanks for the comments, It gives me something to think about.
Hammy
NCFarmLife
Jul 8, 2017 05:40 PM
rvb1975
Ford Truck Parts for Sale
Dec 9, 2016 06:48 AM
MtTheJeffro
13
Sep 1, 2015 09:36 AM
theWeezL
Projects
40
Apr 19, 2011 01:07 PM
Rancha9
22
Mar 28, 2005 11:32 AM
