Vacuum leak?
Old Aug 23, 2015 | 03:12 PM
dnkensinger's Avatar
dnkensinger
Vacuum leak?
Got an odd one here (or maybe not so odd.) My '84 seems to idle just fine (although it is running a bit rich). I have what seems to be decent acceleration through 1st gear and somewhat decent through second gear. Third sucks. Now, I notice that if I accelerate normally while in second gear I get this strange hissing noise that will go away completely if I let up on the accelerator. If I accelerate lightly in second the hissing is non-existent. Anyone know what this might be.
My first thought is vacuum leak but it would have to be something major like an intake manifold gasket (maybe?) Carb gasket should be fine as I just rebuilt the carb and put new gaskets on.
Also, are these factory 2bbl's adjustable in the sense of air/fuel mixture so I can lean it out a little? The exhaust makes me cry (literally, lol)
Old Aug 23, 2015 | 04:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Vacuum should go down as the throttle is opened.
Are you sure you don't have an exhaust leak and a clogged cat?
Old Aug 23, 2015 | 04:28 PM
dnkensinger
Are you sure you don't have an exhaust leak...
I do have an exhaust leak but that is presenting itself as a noticeable tick when the engine is running.
and a clogged cat?
There is not a catalytic converter on this truck. Canada built, no computer if that means anything? No clue, but no cat.
Old Aug 23, 2015 | 07:21 PM
Franklin2's Avatar
Franklin2
Vacuum leaks affect the idle more than anything. A large vacuum leak will not let the engine idle hardly at all. A small vacuum leak will be so small compared to all the air going in the carb at high speed, it does not affect higher rpm operation.
How's your timing?
Old Aug 23, 2015 | 07:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
How's the valve timing???
How many miles are on this engine (or cam chain)?????
Rich fueling and carb spitting (hiss) are VERY indicative of a worn out timing set
Old Aug 23, 2015 | 07:33 PM
dnkensinger
How's your timing?
Have not checked timing yet. That will be next. Something is causing a "hissing" noise while accelerating. Only seems to do it in second gear. Strange.
Old Aug 23, 2015 | 07:35 PM
dnkensinger
well, 42K on odometer, but there's a slight chance it's 142K. Tough to tell. Truck is nearly mint but interior was destroyed (could just be Florida sun for 31 years). I wanna say it's a true 42K but too hard to tell.
Old Aug 23, 2015 | 07:39 PM
Franklin2's Avatar
Franklin2
If you are going to put a timing light on it anyway, loosen the bolt on the dist just a little bit, start the engine and then twist the dist just a little bit till the engine speeds up. Turn the engine off, lock the bolt back down and take it for a test drive, see if it improves.
imradlol
Dec 27, 2016 05:52 PM
SEB72
Feb 21, 2014 06:21 PM
WaR38
Oct 14, 2004 09:37 AM
78custom
Sep 27, 2004 08:48 AM
fozzy
Dec 24, 2001 06:17 AM
