High idle after intake change
Old Feb 19, 2014 | 08:11 AM
SEB72's Avatar
SEB72
Good morning/day all,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I just recently replaced my intake and put a rebuilt 600 cfm carb on my 360FE truck. Anyone have Ideas of why it will not idle down. It is pulling 17.5 inches of vacuum I have tried to adjust the timing but still not quite right. The intake is a F427 edelbrock and the carb is a holly 4160. The sad part for me is My truck is at home in GA and I don’t have room for it with me in IL where I am stationed.<o></o>
Any and all help will be great.<o></o>
Thank you<o></o>
Very Respectfully,<o></o>
SEB <o></o>
Old Feb 19, 2014 | 01:32 PM
85e150's Avatar
85e150
Check for:
-carb idle adjustment
-carb choke/high idle adjustment
-carb throttle butterfly interference and failure to close
-carb throttle shaft wear
-secondary butterfly interference and failure to close
-PCV connection correct
-PCV connection vacuum leak
-vacuum advance connection
-vacuum advance vacuum leak
-brake booster connection
-brake booster vacuum leak
-carb base tightness and vacuum leak
-carb spacer tightness and vacuum leak
-egr port if any, vacuum leak
-manifold vacuum leak at gasket
Old Feb 20, 2014 | 07:29 AM
SEB72's Avatar
SEB72
Talking
Thank you I will try that. When I can.
When I get it working I will let you know what it was.
Old Feb 21, 2014 | 06:21 PM
1972RedNeck's Avatar
1972RedNeck
Ether works good for finding vacuum leaks. Wd-40 will work too if you are feeling smart.
fordfanatik
13
Mar 10, 2012 11:26 PM
norvillebob
45
Nov 2, 2006 07:03 PM
ohiofossil
Jul 4, 2006 08:58 AM
fordtime
Mar 16, 2004 11:34 AM
85f-250-460
Jan 23, 2004 09:43 AM
