several gals of drinking water and a couple of days worth of emergency rations. Fruit/nut bars etc. It can get near freezeing at night. It is a long way from anywheres in some places.
If Evan Tanner was still alive I bet he would agree with you....
Back to the clutch fan question. JB weld won't work. The center
section that houses the clutch does not rotate. It's attached to
the stator assembly. You would have to pull it apart before you
get to the clutch to glue it. If you worried about it maybe going
back to the mechanical type they have in the 7.3 might be the trick.
But I am not sure do to the fact that I have only seen it talked about
in the forums.
Maybe someone has an old one that they would take apart and
post the photos of it. Then you might have an idea on an out in
the dirt quick and dirty fix.
Clayton think Positive, the O'l girl will run just fine, but I guarantee what you will need , because rock, pine needles , cactus don't feel good ( Toilet paper)
If the rental turns out to be low you might just think about one any way.
Be sure to take us photos and post them for everyone to drool over.
Definitely look into it, if the price is right...
Lots of pics and Vids are definitely going to happen.
#1 killer - lack of prep.
Originally Posted by GenMan
quick and dirty from youtube
Perfect thank you!
Oh believe she will run fine, I just like to have a plan so IF something were to happen I have a starting point. I say starting point since plans usually never go as "planned"
If you anticipate any water crossings as I have experienced here in the Arizona desert I always plum the diffs and tranny vents together and terminated high in the engine compartment, when and hot diff hits cold water they tend to suck water in, not condusive to long term diff & tranny life
Thanks didn't even consider that.
There will be at least one water crossing and if it rains there could be more.
I had only one experience in the desert and 1 I will never forget.
When we broke down it was about a 110 degrees just before dark. Within a 1 1/2 hour it was 40 and falling. {Hence the blankets} It was a day and a half before anyone came by, no cell phone service [locals used long range radios]. So good communication equipment is desireable. A good map comes in handy as well. I later found out if I had walked about 3 miles in the right direction I would have found help instead of the 10 mile walk I made in the wrong direction.
How you feeling Danny Boy glad ur back up and running , Did the same thing but out in the woods being a 2 wheel drive my truck got stuck in it's own tracks ( very bald tires) since then the chains and come along has a new home in the tool box
I have a CB I use often, looking into HAM licenceing an such. I love to explore and go way out there sometimes a CB doesn't cut it, HAM has been in my sight for some time now.
I do my best to always have a "paper" map of the area and lensatic compass .. I do have a large book map of all of CA registered off road trails, comes in handy more often then not.
Did you read the page on the rental of the beacons? They also have a
short message function for sending things like "OK" messages. Very handy
if you need to stay longer and you have someone waiting for your return.
Some even go as far as having voice. nit the lesser cost one with messaging
would be ideal for what your doing right now. Later the HAM license would be
good so long as you have power and or a handheld. Always have to keep power
supply in mind.
Speaking of power. Solar battery charge if you can find one with enough output.
EXTRA camera batteries and flash memory for all the cool photos for US left behind.
Haven't looked it up yet as it gets closer I definitely will. Since I do a lot of Hiking an Mountain biking alone (stupid I know) I have been seriously considering a sat phone "plan"
good so long as you have power and or a handheld. Always have to keep power supply in mind.
Definitely always have power supply in mind for all coms
I have one that's pretty good and a kick *** flashlight. One time I had to use both to get my truck to start (dead bat). didn't think it would work, but I also didn't feel like walking so I tried.
I was planning on bringing my backup laptop just to download all pics and vids if I ran out of room on the 32g cards.
