C6 transmission
Old Aug 21, 2015 | 12:08 PM
Beechbum's Avatar
Beechbum
C6 transmission
I just bought a '79 F150 w/351 and a C6 trans. The seller told me when it is cold it may take up to a minute to start moving in drive. He said reverse works fine. Can someone give me an idea of what to do?
Old Aug 21, 2015 | 12:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I would first check the fluid level, then your vacuum lines going to the modulator, might have to replace the modulator. Quick, cheap and easy on the outside of the trans.
Fluid and filter change would be next, after all that, cross you fingers.
Old Aug 21, 2015 | 02:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Those are all good things to check. In this case each one of them are a waste of time and money. The seals in the forward clutch have hardened and need to be replaced. That means the trans needs to be rebuilt.
Old Aug 21, 2015 | 03:02 PM
77&79F250's Avatar
77&79F250
And that is why a public forum is a great thing, thanks for the knowledge.
Old Aug 21, 2015 | 03:09 PM
Roger Carter's Avatar
Roger Carter
There are numerous products on the market that claim to "fix" transmission problems such as you describe. At best, most are stop gaps and band-aids.
If the other correct fixes don't work try adding a pint of lacquer thinner to the trans. This will tend to soften hard seals, and cause them to swell at bit. It is definitely a short term band-aid, but can buy you a bit of time. Tends to clean the inside of the trans too.
Good luck.
Beechbum
Aug 21, 2015 02:30 PM
Hiflyer746
1978 - 1996 Big Bronco
Feb 4, 2010 01:13 PM
cpettymore7777
Sep 11, 2009 05:21 PM
Fourwheelinj1
Feb 14, 2007 03:49 AM
enyaw
Mar 25, 2005 09:25 AM
