Manual steering conversion
Old Aug 1, 2003 | 09:27 PM
DavidJO's Avatar
DavidJO
I have a 1983 F250 HD with 460 engine. I want to change the power steering to manual steering. Who sells the manual boxes? Thanks for any info.
Old Aug 1, 2003 | 10:46 PM
Stingray42's Avatar
Stingray42
why?
Old Aug 1, 2003 | 11:16 PM
GypsyR's Avatar
GypsyR
My only guess would be the salvage yards. Very, very few 80's F series had manual steering. The only one I've ever seen was an 80 F100 SWB stripped down, absolute bottom of the line truck. I've seen one or two in early 80's Rangers too. Even the cheapest of Rangers usually had power steering, even if no other options.
The power steering gearboxes fit from 1980-1996, F100's. F150's,F250's, and F350's. The only difference is the pitman arms and some early 80's trucks had a different hose fitting. The Ranger trucks and Explorers also bolt right up from 83 until they started using rack and pinions (about 95 I think). As long as you use your original pitman arm.
That said, I find it hard to believe you want a manual. An F250 is a heavy truck and having a big block will make it that much harder to steer. Given that any of the above boxes are widely available in the junkyards ($65 around here), I too have to ask-why?
Old Aug 1, 2003 | 11:56 PM
DavidJO's Avatar
DavidJO
I just want the alternator hanging in front of the engine only. I had an early ford truck without power, and you get used to it. I'm in the process of lightening the truck, I'm starting with 5,000 pounds, and I'm looking to get it down to 4,000. I found a place years ago that had rebuilt manual boxes, but I lost their number. Thanks for the replies, but if anybody knows of a place.
Old Aug 2, 2003 | 08:08 PM
78f3504x4's Avatar
78f3504x4
Try Jeff's Bronco Graveyard in Michigan. Just do a search and the number will come up. Also, Ibeling Repair Service in Iowa might have a few, although he specializes in manual-to-power conversions. His # (319) 347-2491.
Old Aug 2, 2003 | 09:55 PM
DavidJO's Avatar
DavidJO
Thanks for the info.
Old Sep 17, 2006 | 05:38 PM
DJOHAGIN's Avatar
DJOHAGIN
Finally got around to it
Well, I finally got around to converting my truck to manual. I have 31 tall by 10.5 wide tires on it. The steering is not really that bad. I found the manual steering box in a 1980 F100 six cylinder. I used the stock pitman arm from the manual box. It bolted right up. I used a 33-inch long 1/2-inch wide V-Belt to go to the crank pulley air conditioning pulley (I removed the A/C) to the water pump pulley. So far I got the truck down to 4,350 pounds. It's stripped down.
Old Nov 29, 2016 | 07:49 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Yes, I'm replying to a 13 year-old message. Just to correct the above statement, manual steering was offered in the Ranger through 1997. Less and less common in the 90's, but still offered until the change to the I-beam suspension in 1998.
Old Nov 29, 2016 | 07:52 PM
Franklin2's Avatar
Franklin2
My 1986 4x4 ranger has the mini ttb I beam suspension under it? Did you mean when they got rid of the I beam suspension?
Old Nov 29, 2016 | 08:23 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Yes, fast typing leads to mistakes. I meant, "through 1998 when the twin I-beam front suspension (similar to the F-series) was replaced by the wishbone-style system found on the Explorer."
Old Nov 30, 2016 | 11:52 AM
Nothing Special's Avatar
Nothing Special
This doesn't really matter, as long as everyone understands each other communication works. But there's no such thing as a twin I beam 4WD front end. I beams are solid chunks of metal that have a cross section shaped like the letter "I". No way to get a drive axle through it. When Ford made a front drive axle with geometry similar to that if their Twin I Beam (2WD) front suspension they called it "Twin Traction Beam" (now usually abbreviated TTB). Again, it doesn't really matter, except if someone gets confused when you talk about a 4WD vehicle with a 2WD front end.
Old Nov 30, 2016 | 03:02 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
I'm wondering if there wasn't some confusion with the older F-Series Ranger Package and the newer B-Series Ranger.
Old Nov 30, 2016 | 06:07 PM
Nothing Special
I'm pretty sure he's talking about the Ranger pickup (not an F-series with the "Ranger" trim package), before it switched from Twin Traction Beam to the later style (wishbone, I guess, I never paid much attention to trucks newer than 96/97)
pchelp
Jul 17, 2017 03:48 PM
shty150
16
Jul 5, 2017 09:59 AM
Josh Hopkins
Oct 22, 2016 02:23 PM
hombre292
Aug 25, 2016 08:17 AM
roadrash63
Apr 30, 2016 07:42 AM
