General Diesel Discussion
Power but no start
Old Aug 18, 2015 | 06:52 PM
Shooter19d's Avatar
Shooter19d
Power but no start
Hello all,
I have a 1999 F250 power stroke 7.3. Six speed t was running one minute fine and then I went out to my truck to start it and there was power but the engine would not turn over. I am able to start the truck if I put a screwdriver over the fender mounted solenoid. I know the issue must be in the ignition somewhere but any help on where to start would be great. If you could be specific and locations as well that would be appreciated.
Old Aug 18, 2015 | 11:09 PM
Ford_Six's Avatar
Ford_Six
It's probably that starter relay you jumped. They do go bad. Take the wire off the small terminal and run a jumper wire from there to the battery + post (make sure the truck is in neutral). If nothing happens, there's your problem. If it does crank, then move further back in the system. Clutch switch, and then ignition switch. Both of those can be tested right under the dash at the clutch pedal rod.
Old Aug 18, 2015 | 11:27 PM
Shooter19d's Avatar
Shooter19d
Found it
Thanks ford_6. It turns out that it was the clutch switch. I'm glad that turned out to be an easy fix. Thanks for the help
Old Aug 19, 2015 | 11:25 PM
Ford_Six's Avatar
Ford_Six
Glad you got it sorted.
rowdyredneck
Jul 1, 2017 09:48 AM
Tim Enigma
Jul 14, 2015 01:14 PM
Freighttrain
Nov 23, 2014 10:59 AM
theredneckrussian
Dec 23, 2013 03:33 PM
jchilcot
Aug 24, 2008 08:48 AM
