6.4 to 7.3 idi swap
#121
On the other hand, when I can pick up an IDI for under $200 in running condition, and Cummins motors are in the multi-grand range... I figure an IDI'll get the job done. And parts are widely available and cheap, too.
#122
I suppose it all depends on your budget. If you are having a shop doing the conversion, you might as well spend the extra money on the 'best'.
#126
Its going on two years now and I haven't had any problems with the truck. I have added a back-up camera and a second 40 gallon fuel tank where the spare tire would go. I do add wire connectors to anything I add just in case I have to pull the cab, i wont have to cut wires. Still overall very pleased with the truck.
#127
That truck is going to be going to the grave with you then.
#128
#129
Coleton_henry
17
11-01-2017 12:56 PM
77highboyowner
10-30-2007 12:43 PM
