IDI oil change interval with full synthetic oil
I use the Rotella T4 15W-40 also, Castrol Edge would be a good synthetic .... the Rotella T4 is a short life oil but I doubt many here do SOAP on their engines.
good read here ===>> https://www.linkedin.com/pulse/dont-...s-john-moseley
EDIT: for those that don't know SOAP ====>>>> https://www.sciencedirect.com/scienc...08043922500345
If you want to run synthetic and extend your oil drain interval, OK... but you need to do the other piece of the puzzle - add a very tight bypass filter(frantz, amsoil, or a centrifuge) to keep the oil clean.
I mean, honestly we probably could run 15W40 dino oil over 5K miles in terms of the oil breaking down... but by around 3K it's pretty filthy already.
I personally just use cheap Mobil Delvac 15W40 and change every 3K or so. And the inside of any engine I've run for a year or more has been spotless inside... despite having tons of miles on it.
I've also opened up motors that have *not* had their oils changed as frequently as they should, and the sludge isn't pretty.
