Sponsored by: Real Truck
Need help with door locks
Old Aug 17, 2015 | 04:27 PM
Ryan Brattensborg's Avatar
Ryan Brattensborg
I recently purchased a 2003 F-250. The door locks don't work properly, the passenger side will lock the entire truck all 4 door locks actually lock. The unlock on the passenger side does not work and neither does the entire switch in the driver side. I attempted to switch the actuall switches from the driver to passenger side thinking that it could be a switch that is broken. After doing that still only the passenger side would lock and the rest of lock unlock buttons did nothing. I have checked all the fuses in my truck and actually took the door panels off today thinking I might find an obvious problem. I know the actuators are a common problem but because all the locks lock in the vehicle I was thinking it might be something else. Any guidance would be appreciated on where to look next, the ford dealership wants $100 an hour to diagnose it and they told me to expect about an hour a door until they find the problem, I don't have 400 dollars to spend on door locks so I would greatly appreciate and guidance.
Old Aug 17, 2015 | 05:51 PM
Vwags's Avatar
Vwags
I would start at the switch on the drivers door and check for power and ground to the switch and out to the actuators when activating. The actuators are 2 wires that change polarity depending on which way you are asking it to go.
TruckoffFord
Jul 25, 2011 05:34 PM
DaBossF250
1997 - 2003 F150
Dec 18, 2007 11:01 AM
jonboy88
20
Jun 12, 2006 03:35 PM
Crash55
Electrical Systems/Wiring
Oct 16, 2002 02:59 PM
