Transmission drain plug
Old Aug 13, 2015 | 07:32 AM
Steve's Avatar
Steve
Here is my 3-speed trans drain plug looking sad and wallered out.
Too big for the 3/8" drive and to small for the 1/2" drive. It's a good one because it has a little magnet on the other end, so I'd like to use it. Any ideas on how to improve this one so it can be tightened?
Old Aug 13, 2015 | 09:16 AM
52 Merc's Avatar
52 Merc
Pipe plugs are cheap and plentiful, even with a magnet on the end. But it you're determined to use that one, you may be able to weld up the corners better and grind them square again, or find an old, short 1/2 drive extension and grind/file the tip to seat square in the hole.
Old Aug 13, 2015 | 10:06 AM
jniolon's Avatar
jniolon
old and in the way
I agree with '52... but if you want you can cut a hex head bolt short and weld it into the plug recess then use as boxed end wrench to turn it... or you could go roll around in a u pull it and steal one out of a transmission.. probably in about the same shape as yours...
if you can't find one with a magnet... epoxy a small button magnet to a new one at the APS... I epoxied a magnet in the bottom of my drain pan during the build..
john
Old Aug 13, 2015 | 12:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Those plugs are usually cast iron, so welding isn't worth the trouble. Get a new one that isn't recessed, that sticks out with a square head. You can glue a magnet in them.
Old Aug 14, 2015 | 08:04 AM
Steve's Avatar
Steve
Thanks guys. Sometimes the simple solution eludes us I guess.
A pipe plug and a super magnet JB welded in the end did it.
sheevesakatyler
Jun 8, 2019 08:03 AM
akblackfoot
Jul 30, 2016 06:25 AM
jaybe
Jun 24, 2007 07:54 PM
98 4.6 locked up
1997 - 2003 F150
Mar 18, 2004 01:44 AM
HD
Oil & Lubrication
16
Jun 11, 2003 05:49 AM
