88’ zf5 drain plug
Old Jun 7, 2019 | 09:24 AM
sheevesakatyler's Avatar
sheevesakatyler
88’ zf5 drain plug
Does anyone know the size of the drain plug on a 88 f250 zf5? Most places have it listed as a m22 hex head, like a normal drain plug, but the ones in my trans more resemble a larger differential plug, as in 3/8 ratchet size hole in a plug, also larger than an m22. Almost like fine pipe thread also. Any help here as to why mine are different than all the others I can find would be appreciated
Old Jun 7, 2019 | 08:19 PM
EllieMae94's Avatar
EllieMae94
The one on mine out of a '96 is a hex head, M22. I wonder if someone put that differential style plug in there because that's all they had lying around. Could have lost or stripped the original hex head?
Old Jun 8, 2019 | 02:01 AM
sheevesakatyler
I’m not sure, these ones are bigger than an m22 by at least a size or two and both ,drain and fill plugs, are identical differential plug style. It’s weird that they’re matching to not be original but I can’t find info on them anywhere
Old Jun 8, 2019 | 08:03 AM
ford390gashog's Avatar
ford390gashog
Early ZF5 units used 10mm square drive drain and fill plugs. A 3/8" ratchet also fits, Early ZF-5 units were imported.
JDDINMINN
Feb 2, 2018 08:43 PM
BII Plow Truck
Oct 26, 2017 07:14 PM
skyfox10
Oct 6, 2017 01:47 AM
Dustin_86
Jan 15, 2011 01:35 AM
56efffie
Feb 27, 2003 12:34 PM
