Additive in coolant?
Old Aug 14, 2015 | 06:36 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Thomas White
Mr. Stewart,
You are partially correct.
No, I'm completely correct.
You said to test OAT for SCA's. An OAT coolant doesn't contain SCA's.
1. A Dual Scale Refractometer measures both.
But again, your post said to test an OAT coolant for SCA's. You didn't suggest a dual scale refractometer that can test SCA's as well as the inhibitor base that makes OAT coolants work.
2. SCA's can be added to any coolant produced for motor vehicles.
If anyone does that to an OAT coolant, it will effectively ruin it (subjective opinion).
One of the best features about OAT coolants is the fact they don't contain SCA's and don't need SCA's to prevent cavitation. Adding SCA's to an OAT coolant eliminates that feature and from then on, a person will need to test the SCA level of the coolant to make sure it remains effective.
Originally Posted by rufushusky
You can still check the inhibitor package on a ELC, it is just a different test strip than the traditional DCA2 and DCA4 type test strips.
Yes, I know, aint it cool now?
They didn't have test strips for OAT coolant for years. Years ago Gooch explained to me how one could test their OAT coolant, but it would mean getting a baseline on the coolant when it was first put in the truck.
Thanks for that link, rufus, I'm gonna add it to my Gooch Coolant thread.
Stewart
Old Aug 25, 2015 | 01:00 PM
lawdawg79's Avatar
lawdawg79
Well since i havent been able to get around to flushing my coolant system and adding an hd elc i stopped by advanced and added a bottle of hy-per lube diesel super coolant. It says acts as an sca and provides 100% protection from cavitation, corrosion, amd electrolysis and is compatible with all types of coolant. I put the whole bottle in, it says one bottle for 26 quarts, so it's a bit short as i believe the entire 7.3 system is 32 quarts. Hopefully this is the right thing to get me by until I can get the right stuff in there
ryanrk12
6.7L Power Stroke Diesel
Jul 30, 2019 12:33 PM
fski50
Apr 26, 2015 08:28 PM
Duane99
Apr 16, 2006 10:50 PM
SpringerPop
15
Nov 22, 2005 02:23 PM
sterling
Feb 8, 2005 08:47 AM
