Dead Injector only at Elevation??
Old Aug 10, 2015 | 06:22 PM
th3_d0c's Avatar
th3_d0c
I was up on PikesPeak (10k-14.5k feet) a few months ago for the races. During practice, when I would be atleast 12k+ feet and sit there off for 3-5 hours, after starting the truck, it sounded like a piston was going to bust through the engine when under power. During idle/engine breaking (downhill, low gear) it was fine. And once I got to a lower elevation, it completely disappeared.
I am guessing the piston sound is an injector not working. But what does it mean that it only happens at elevation? There is air stuck in there? Leak? Weak injector?
**This is after driving 2,000 miles from SanFran.
1990 F250 7.3 with Aftermarket ATS 093 turbo.
Old Aug 11, 2015 | 05:55 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
I live in Denver, and drive at 12k' frequently, and I can tell you that it is not a normal thing. You see a lot of black smoke at elevation, but I have never had those kind of problems.
Old Aug 12, 2015 | 02:55 PM
S.P.'s Avatar
S.P.
I'm watching this post.
Old Aug 12, 2015 | 03:20 PM
th3_d0c's Avatar
th3_d0c
I know it definitely isn't normal. But it was interesting that 1. It only happened after sitting for a bit (making me think there is an air leak that wasn't clearing at elevation) and two, I don't hear it when I am idling/engine breaking downhill. Only when I push on the throttle.
Hah.
Old Aug 13, 2015 | 11:12 PM
Macrobb's Avatar
Macrobb
This is an injector failing then. Decellerating = no fuel going into the engine
whitesdford
15
Nov 4, 2008 05:45 AM
aocabrown
33
Apr 2, 2008 10:24 PM
97 HD
19
Oct 22, 2007 03:54 PM
ATSDRIVER
Dec 24, 2005 04:02 PM
mhannink
Dec 1, 2005 07:42 PM
