93 7.3 idi glow plug controller ?
Old Aug 7, 2015 | 09:42 PM
brandon gibson's Avatar
brandon gibson
I put new glow plugs in today. Still a pain in the *** to start. GPC has 12.3 volts to it(hot side) and 6 volts on the out side (with switch on start)that has the metal ribbon on it. WTS light comes on for about 3 to 5 secs like it always has, its like it never made a difference. I knew the GPs were bad to start with it. But I don't know the correct voltage on the outside of the GPC and I only have 3 or 4 volts at the plugs Is this correct?
Old Aug 8, 2015 | 06:01 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE
what type glow plugs did you put in? if anything other than motorcraft ZD-9's, they are probably burned out already.
Old Aug 8, 2015 | 09:01 AM
brandon gibson
They are autolites. I'm on a budget and couldn't afford the Beru's. But they wouldn't burn up on the first start. There is something wrong with GPC I believe or the GP wiring harness. Any trouble shooting pointers other than not using ZD9 is your reason for a hard start. I've read all threads on here I could find about this but didn't see anything about correct voltage readings.
Thanks
Old Aug 8, 2015 | 10:38 AM
brandon gibson
I checked the GP they are all still good but still and a pain to start the WTS came on for about 8 secs this time but still took 3 times to get it to start at 10 sec cranks a piece
Old Aug 8, 2015 | 12:31 PM
sjwelds's Avatar
sjwelds
Oh yes they would.
So what's cheaper: the right plugs (Beru's) or pulling the head to get a broken glow plug out? I'll leave it up to you....
Old Aug 8, 2015 | 12:34 PM
tjc transport
i ain't rite
i have seen way to many sets of autocrap glow plugs burn out after one start. and a few that burned out before even firing the engine once. they should be banned from selling glow plugs.
and i bet you paid the same thing for those autocrap plugs than you could get motorcraft plugs for too. rock auto has the ZD-9's for $9.17 each
before i ruled the glow plug controller bad, i would put the proper glow plugs in to see if that is truly the problem.
these controllers are designed to work with the motorcraft/beru plugs. the other manufacturer plugs will not work properly.
i have seen people waste all kinds of money throwing parts at these engines and finally bring it to me. i pull the garbage glow plugs out and put ZD-9's in and sent it home with the people swearing i did magic to it because they simply refuse to believe it was just the wrong glow plugs that was the problem all along.
Old Aug 31, 2015 | 03:00 PM
jeffbradbury7's Avatar
jeffbradbury7
on mine I had voltage, but some of the wires were pretty fried. Fixed all the GP wiring, works fine. I hope I put Motorcraft plugs in, but I don't remember.
Old Aug 31, 2015 | 04:31 PM
hs108's Avatar
hs108
Take those Autolites out and return them RIGHT NOW.
Follow my steps carefully and I can help you...
1: Take those out and return them
2: Go on advance auto order 8 Motorcraft/Buru ZD-9 plugs and 1 motorcraft FL1995 oil filter
3: Type in Code TFT41
4: Pay 7.07 each for the ZD9s and 6 Bucks for the filter
5: Install and watch magic happen
Also check out this link for information on the GPC and how to test the correct voltage at the GPs
http://www.oilburners.net/forums/sho...lug-connectors
Old Aug 31, 2015 | 08:12 PM
norm805's Avatar
norm805
Sounds like your problem could also be air in your fuel lines .
klle5
Dec 25, 2015 11:06 PM
kent hittle
Nov 21, 2015 06:56 AM
vfelix702
Jan 13, 2011 07:04 PM
Twin34
Jan 4, 2009 04:17 PM
rockcrawlerdude
Feb 26, 2007 04:26 PM
