okay i just got a 89 7.3 idi last weekend and im having minor probs ( tach sensor - which may be causing my tranny's weird shifting) and my glow plug only cycle when the engine has been run??? when i go to turn it on for the 1st time that day the "wait to start" light wont come on , yet once you drive it somewhere and shut it off even for up to an hour or so the W T S light will come on and it wil fire right up... the glow plugs are new from what the previous owner told me , so my question is why wont the glow plugs (or the wait to start light) not run when its cold??? i would think it would be the opposite ( not cycle when warm). any info on how to remedy this would be great.. ive seen on another truck, where the guy has directly wired the glow plugs to a push button in the cab ( hold for a few seconds and your good to go) is this an easier fix for this prob? thanks agian.. N8
well, if the po told you the plugs are new, he probably put a garbage brand plug in it. and you very likely have a bad connection on the controller. that would give you a no glow on first start, but as you drive around, you vibrate the connection enough to let them come on when warm.
