Minnesota Chapter Join Chapter, Leader: fordpower88
Hot August BS Thread
Old Aug 11, 2015 | 04:37 PM
  #166
DieselCamper01's Avatar
DieselCamper01
Busy is right. I cannot keep up with the dang emails.
Old Aug 11, 2015 | 04:43 PM
  #167
MisterCMK's Avatar
MisterCMK
Originally Posted by wildstang
Transmission question for Dave, Mike and anyone else with knowledge of them. my 01 excursion since we have owned it has acted strange in cold weather when first started. unless warmed up for like 3 minutes or more you put it in gear and it would be real sluggish moving but the rpms would be up and less then quarter mile would seem to act normal. I used to think that maybe it was some sort of cycle in the computer to let the transmission slip a little to help avoid damage to other components when cold. Late this spring we drove it around a 100 miles and I picked my son up from a boy scout event, when I backed up if felt like it spun in mud, there was mud in the parking lot. when I got up to the paved road it still was slipping so I knew that wasn't it. I couldn't really tell if it was low on fluid so I added some to be safe. It still wasn't right. it has gotten progressively worse fast for hardly driving it. I don't even think I have put 300 miles on it since the problem. My parking area has a slight decline and to the point now that I put it in reverse it barely gives enough to role back and when I put it in any forward gear it acts like neutral. It will eventually, I guess, build up enough pressure to move but not well. and then when you have it in gear and foot on the brake it act like in neutral and then act like it is loading the engine more then normally would.
I did ask in the 7.3 forum and Mark, who is the retired ford transmission engineer, said there are 3 feed bolts under the valve bodies and if those loosen then that could give those symptoms. I am in the process of removing the valve bodies to check but I doubt that is it. Do you think the pump would go out that fast and act this erratic? I'm going to put it back together with new fluid and hopefully check line pressure soon. thanks.
Have you put a gauge on it to take a look at the pressures yet?
Old Aug 11, 2015 | 08:36 PM
  #168
dlibson's Avatar
dlibson
Evening everyone. Football has started here again, so 4 days a week are nuts...
Jim, it really sounds like tranny time to me. Checking pressures would be next step in diagnostics. But if you've been driving it with low pressures, it's done anyways.
Old Aug 11, 2015 | 09:43 PM
  #169
wildstang's Avatar
wildstang
VT Chapter Ldr
I plan to hopefully Thursday. I checked the three feed bolts under the valve bodies and those were still fairly tight. Got the valve bodies back in. Pan and fluid next.
Old Aug 11, 2015 | 09:49 PM
  #170
fordpower88's Avatar
fordpower88
Sounds like it is time for a BTS!
Old Aug 11, 2015 | 10:11 PM
  #171
wildstang's Avatar
wildstang
VT Chapter Ldr
Would be nice but not the $4000 to do it
Old Aug 12, 2015 | 05:58 AM
  #172
dlibson's Avatar
dlibson
Good morning everybody and welcome to hump day.
Old Aug 12, 2015 | 06:04 AM
  #173
Big-Foot's Avatar
Big-Foot
Good morning Dave and the rest of the Minnesota gang!
Old Aug 12, 2015 | 06:33 AM
  #174
HP junkie's Avatar
HP junkie
Good morning fellas!
It's Hump Day so get busy!!
Old Aug 12, 2015 | 07:40 AM
  #175
DieselCamper01
Good morning Dave, Randy, Cory.
Old Aug 12, 2015 | 08:25 AM
  #176
fordpower88
Good morning Dave, Randy, Cory, Jay and the rest of MN!
Have a successful Hump day everyone!
Old Aug 12, 2015 | 08:26 AM
  #177
wildstang's Avatar
wildstang
VT Chapter Ldr
Good morning and have a productive hump day Dave Randy Cory Jay Troy and MN
Old Aug 12, 2015 | 09:35 AM
  #178
DieselCamper01
I will give it my best guys but don't hold your breath.
Old Aug 12, 2015 | 09:47 AM
  #179
fordpower88
All you can do is it give it your best shot Jay!
Old Aug 12, 2015 | 09:57 AM
  #180
fordpower88
Beer anyone.......
