no start
Old Jul 29, 2015 | 08:52 PM
zangetsu's Avatar
zangetsu
no start
2008 ranger 3.0. Started off with replacing the pcm which gave me the ability to start it with ether. Its got good fuel pressure good fire. Replaced the cam and crank sensor. But still won't start. Checked injector pulse and it is intermittent. Thoughts and ideas would greatly be appreciated.
Old Jul 31, 2015 | 05:19 PM
g_k50's Avatar
g_k50
Have you checked the compression?
How many miles?
Why did you change the pcm? Are the pcm's the same or from different series?
So it turns over ok, used to start with ether? that's a fuel problem.
You replaced the cam sensor? or the cam?
If you replace the cam, check you static timing with the valve cover off.
Valves should be closed with piston on the compression stroke.
Old Aug 4, 2015 | 01:30 PM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Scan the ECM for trouble codes & post All code Number clues.
Kawmotodad
May 18, 2018 10:17 PM
jhooch
Oct 22, 2012 09:36 PM
92rangerman
18
Jul 1, 2012 11:04 PM
HTP
Mar 19, 2012 10:07 AM
dirtmonkey11
Sep 10, 2010 10:25 AM
