97' Ranger, not starting
Old Aug 4, 2015 | 11:39 AM
hobbyman's Avatar
hobbyman
4wd Low
Cool 97' Ranger, not starting
This is a 3.0 V6, base, bare-bones model.
I was trying to fix a problem (horn stopped working).
So, dummy me, removed and put back in every fuse (just checking to make sure the fuses are all good). I took one out at a time and was careful to put them back in exactly as they came out.
Now the thing won't start.
It spins over but won't start.
It's almost as if something to do with fuel has been disabled.
(it was starting just fine before my tinkering)
I checked the inertia switch and it's not tripped.
I have taken the negative battery off and left sitting for long periods of time and that hasn't helped.
I don't think it has the Ford anti-theft (PATS) because the original key is a slim key (not a fat key that contains a chip).
Any ideas on what could be disabled?
Old Aug 4, 2015 | 12:31 PM
pawpaw's Avatar
pawpaw
If it has PATS, it'll have a dash blinking "Theft" light indicator when the key is off.
It could have PATS & someone lost a key, didn't want to pay the Dealer ransom for a replacement, so just went to Wally World & had a plain key copy cut that would unlock the ignition & steering & taped the chipped key under cover, like to the steering column, or close by under dash, where the PATS antenna could read it.
If so & you had the ignition key on when disconnecting power, the PATS thinks your trying to steal the vehicle.
Old Aug 4, 2015 | 12:36 PM
hobbyman's Avatar
hobbyman
4wd Low
No, I'm the only owner for the truck. Original keys.
There is no "Theft" light indicator on the dash.
Old Aug 4, 2015 | 01:53 PM
pawpaw's Avatar
pawpaw
OK, good feedback, no PATS. SO, lets think about this some more. If it was starting & running ok before the fuse pulling exercise, then revisit All of the fuse Locations, to make sure you didn't plug one into a vacant spot, right next to where its supposed to go.
Old Aug 4, 2015 | 01:54 PM
hobbyman's Avatar
hobbyman
4wd Low
I'll double-check, thanks. Let you know what I find.
Old Aug 4, 2015 | 02:59 PM
hobbyman's Avatar
hobbyman
4wd Low
Double-checked and I had misplaced the fuse for ignition coil to the open slot right below it.
Thanks
(Now I'll make a new post for my original problem)
Old Aug 4, 2015 | 03:39 PM
pawpaw's Avatar
pawpaw
Ok, good find & feedback.
corvairbob
Mar 21, 2015 07:21 AM
rsplash40
Oct 21, 2012 01:14 PM
kornfanjoe
Apr 1, 2012 03:58 AM
BigDfromTN
2004 - 2008 F150
Feb 9, 2007 03:10 PM
