mirror upgrade to newer rectangular style
Old Jul 27, 2015 | 05:23 PM
Gary E's Avatar
Gary E
is the aftermarket making a plug and play swap yet or do we still need to swap wires to get the power mirror to work right?
I wouldn't mind wiring up the fold mechanism is it all self contained or is external relays needed.
any vendors you suggest. I see them as cheap as $185 a pair on flea bay.
Old Jul 28, 2015 | 04:52 AM
Supercab's Avatar
Supercab
I just went through this, I really thought about aftermarket mirrors, but found a nice set of take off OEM on Ebay from a seller in Indiana.
I only wanted to do this one time.
I have a '99, so there was no plug and play.
I didn't have to have the power fold and telescoping.
I used covered male/female spade connectors for the 3 mirror power wires on each side, and common 4 flat trailer connectors for the running light, signals, heat and ground, worked out real well.
I think if you have lighted and heated mirrors now it would be a plug and play....
Old Jul 28, 2015 | 05:07 PM
F250_'s Avatar
F250_
Plugs are different. With newer Ford mirrors (takeoffs) you'll need to use some adapter plugs to make it look like OEM wiring. Otherwise, you have the option mentioned above. I believe I've read, though, that the newer aftermarkets can be had with plugs which match your existing setup.
Old Jul 28, 2015 | 09:43 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You can buy aftermarket mirrors from 1AAuto that are designed for people with 99-07 trucks, and are plug and play.
Tony here on the forum will hook you up if you have questions.
Old Jul 29, 2015 | 10:36 AM
F250_'s Avatar
F250_
That's what I thought I remembered, Trey. Thanks for the confirmation.
Old Jul 29, 2015 | 11:09 AM
GregA's Avatar
GregA
What are you going from and to? I used the following adapters to install later mirrors on my '01 Excursion. Mirror turn signals don't work (requires add'l wire) but mirror control and heaters do.
Ford Mirror Wiring Adapter - 1AZMA00005 at 1A Auto.com
MacsV10
May 1, 2018 02:45 AM
nagetech
Jul 7, 2015 12:45 PM
bergy 2000
Dec 17, 2012 04:30 PM
impy
Jan 8, 2004 01:10 PM
Code 5 Ford
Nov 15, 2003 09:17 AM
