Chirping under heavy load
. I've been doing a lot of research the past couple of days at work, desk job without oversight
gotta love it!, and it really sounds like that is probably the issue. Some additional things I've noticed is a small smell of exhaust in the cab. Didn't mention that before as it was there before the oil cooler upgrade, but gone right after I put it back together, but then reappeared about the time of the noise. Figured it was just normal. Lack of power on takeoff/very slow to spin up the turbo sometimes but not all the time.What is the best way of getting it to align without disassembling all kinds of crap again. I'm tired of the hood up, it's been up more than the truck has been on the road it seems like! I ran across a video of a guy and a ratchet strap to pull it in. Is that a good idea? I also ran across a video of a guy and a spray can of copper gasket maker. Is that a good idea? Seems like I should probably be loosening up the turbo bracket or the turbo, loosen up the bolts at the other end of the y pipe, and then put it together with the v-clamp and tighten everything back down. What is the minimal that has to come out, degas? FICM? air intake pipe to turbo? I'm also starting to think the bellows might be leaking as I could smell exhaust before doing the oil cooler, could have just been a leak though elsewhere. I poked a light up in there real quick like and didn't see any soot from underneath. Is there a way to tell without pulling it out?
I'm planning on doing this Saturday. I'm also gonna pull all the boots, clean them up put them back in. Also gonna check and make sure all the other v-clamps are tight. I only had a few minutes last night with a flashlight, but I didn't see any soot or anything around any of the v-clamps at all or any signs of leakage at the boots.
Haven't started shopping around too much yet. Are the MBRP's a better alternative to the OEM? Since I have to replace it, I'd rather not go stock unless they've improved the design and this won't happen again. Otherwise, I'd like to get an improved design aftermarket without spending a fortune. Suggestions/recommendations?
