6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
diagnosis please
Old Jun 17, 2011 | 10:55 AM
Texas450's Avatar
Texas450
diagnosis please
What's up guys ....right now im in corpus christi and have noticed my truck is letting off a very high pitched noise sounding when I press the pedal from a stand still. When im idle it doesn't make the noise. My turbo has never made this high pitch noise before ....is my turbo going out??? The turbo is lagging but there as always been a delay. Power I think is the same and mpg is same from what I can tell.....
Thoughts please
Tex
Old Jun 17, 2011 | 11:24 AM
parkland's Avatar
parkland
Making normal boost?
Old Jun 17, 2011 | 11:33 AM
Texas450's Avatar
Texas450
Yes it is....just sound horrible .....belt maybe?....... but if it was the belt shouldnt it make the noise when I am idle and pressing the gas?
Old Jun 17, 2011 | 11:40 AM
senix's Avatar
senix
I would tend to think under load the belt has a better chance to squeal.
As far as turbo goes they have been pretty dependable.
Might just take a gander at the intake tubes. Shine a light in there and see if there is anything that you can see trouble wise.
Also shine a light all around the outside of the turbo, verify if there are any leaks at the oil lines that feed the turbos.
Old Jun 17, 2011 | 03:28 PM
bnmccoy's Avatar
bnmccoy
I take it the noise is only when accelerating? Coincides with making boost?
If you had a 6.0 I would suggest you have blown head gasket(s) and the noise is the squeal of excess coolant system pressure escaping from the degas bottle cap.
I wouldn't expect same from a stock 6.4 though; nor did you mention any coolant issues. Everything okay level wise under the hood for both coolant systems?
Hopefully it is just the belt slipping.
Good luck,
Bob
Old Jun 17, 2011 | 03:47 PM
Texas450's Avatar
Texas450
The truck is not stock...it has a dpf delete and programmer with a cold air induction. All fluid levels are just fine and normal levels..... the problem only seems to happen when I accelerate... I am making more black smoke then is normal... I assure you I do not a hot rod my vehicle as this is my office.... I do you feel like I have some power loss.... at highway speed I do not hear the noise anymore but I feel as if I can't get up and go when I need you
Old Jun 17, 2011 | 04:20 PM
Texas450's Avatar
Texas450
Voice text sucks....the last word is supposed to say ...to
Old Jun 17, 2011 | 06:25 PM
cheezit's Avatar
cheezit
broken y-pipe is a possible as well
Old Jun 18, 2011 | 09:59 AM
Texas450's Avatar
Texas450
What is the y-pipe? And is that major?
Old Jun 18, 2011 | 10:33 AM
bushman134's Avatar
bushman134
Check the rubber boots on the turbos might be a small leak there or a crack in one of them. just a guess but have heard of this before
Old Jun 18, 2011 | 04:53 PM
bnmccoy's Avatar
bnmccoy
It is the 'Y' formed where the two pipes from the exhaust manifolds come together before connecting to the turbo.
Cheezit works on them daily; so he knows what he suggests
Old Jun 18, 2011 | 09:06 PM
bigcountryfs's Avatar
bigcountryfs
i have a 2008 f-350 4x4. mine had the same squeal during acceleration, the down pipe from turbo to exhaust between motor and firewall was cracked.
Old Jun 18, 2011 | 09:08 PM
Texas450's Avatar
Texas450
Was that pricey???
Old Jun 18, 2011 | 11:47 PM
66stang351's Avatar
66stang351
Was that pricey???
Good excuse to get a better than stock one if it is the problem... AFE Mach Force XP Race Down Pipe Upgrade 49-43025
Old Jun 19, 2011 | 07:22 PM
bigcountryfs
i was told they needed to pull cab to make it much easier, some might do it without pulling it. luckily mine was still under warranty.
