Replacing Motor Mounts
Old Jul 25, 2015 | 10:18 PM
85AustinTucker's Avatar
85AustinTucker
I have a 1985 F-150 4x4 with an inline 6. The motor mounts are worn out in it and I am planning to replace them in the next couple of days. I am also planning on replacing the oil-pan gasket and the oil pump at the same time since it will be accessible. I am looking for some tips/advice on the easiest way to get this done the first time. If anyone has any experience on this I would appreciate some advice and feedback. Thanks, Tucker.
Old Jul 26, 2015 | 06:53 AM
Franklin2's Avatar
Franklin2
Do you have a engine crane? On the v8's you have to lift the engine up to get the pan off.
Old Jul 26, 2015 | 07:26 AM
maytag906's Avatar
maytag906
On an 86 I had years ago, with the I6 engine, I lifted the engine just enough to pull the pan, by removing the bolts from the motor mounts, and lifting the engine with a floor jack, and block of wood. I carefully jacked up the engine, using the harmonic balancer as a jacking point. When high enough, I placed blocks of wood where the motor mounts went. Of course you have to remove shroud, etc.
Old Jul 26, 2015 | 09:25 AM
85AustinTucker
I don't have an engine crane but I was thinking about renting one to do the 2 motor mounts and then using a floor jack for the tranny mount. Also, are there any restrictions for when I lift the motor? Ex, am I going to have to remove/disconnect any parts that might get in the way?
Old Jul 26, 2015 | 10:04 AM
DeereFord300's Avatar
DeereFord300
Depending on if you have removed the emissions equipment/feedback system, some of it might have to be loosened or pulled off
Old Jul 26, 2015 | 02:20 PM
Franklin2's Avatar
Franklin2
The first thing that will hit is the fan to the fan shroud.
945SPD
13
Feb 13, 2019 05:33 PM
b1pw3ha
Feb 21, 2006 07:19 PM
Broncobudy
1978 - 1996 Big Bronco
Apr 7, 2005 07:11 PM
ford86
Nov 24, 2002 12:28 AM
supercab78
Mar 24, 2002 01:29 AM
