Transmission problem.
Old Jul 25, 2015 | 03:48 PM
Alex from GA's Avatar
Alex from GA
We have a '99 Explorer AWD with the 5.0 and the 4R70W transmission. This morning the "OD off" light started blinking. I looked it up in the owners manual and it said "see your tech" or something like that. I drove it on the freeway and the only thing I can see different is the RPMs are a couple of hundred more @ the same speed. It shifts fine. I put a couple of quarts of fluid in it just to be sure. The white plastic stick is hard to read. Does anyone know what the problem can be before I take it to my repair guy? Thanks.
Old Jul 25, 2015 | 03:58 PM
nussford's Avatar
nussford
Im betting you are not going into overdrive. Count your shifts. Thatll tell you what gear its in at freeway speeds.
Old Jul 25, 2015 | 04:03 PM
Alex from GA
Yes it's going into OD. What I'm worried is the lock up converter isn't locking.
Old Jul 25, 2015 | 04:05 PM
nussford's Avatar
nussford
Or that too. Id say its one of those two.
Old Jul 25, 2015 | 05:10 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That was a very, very bad idea. If it is overfilled it can cause a fire.
No, nobody knows what's wrong. The ONLY way to find out is to get the codes read. The places that read codes free CANNOT read these codes. Your repair guy can if he has the right tools. If he doesn't, he most likely can't fix this.
Old Jul 25, 2015 | 06:03 PM
Alex from GA
Thanks Mark, I'll call him Monday.
Old Jul 29, 2015 | 07:28 PM
Alex from GA
Update. Monday afternoon, after driving it all day, the blinking stopped and the light went off. I'm pretty sure the lockup is working. I'm still going to get the codes read if they're still in the computer
dieselmom
23
Feb 12, 2020 12:14 PM
ford1floyd
2004 - 2008 F150
Apr 13, 2012 06:59 PM
bakerbuilttracks
Nov 4, 2009 07:06 AM
cnd999
13
Nov 14, 2005 07:57 AM
Johnboy_BoomerSooner
1997 - 2003 F150
Mar 5, 2004 02:43 PM
