Another transmission problem
Old Apr 13, 2012 | 11:39 AM
ford1floyd's Avatar
ford1floyd
I was reading cattlerancher's post ,but my problem is a little different from his.
I have a 2008 Ford Lariat F150 with 53k miles. The transmission seems like it slips at times. Here's the scenario. When I take off from a standstill and going through the gears at a normal acceleration pace, say I momentarily lighten the acceleration pace then try to resume. At that point, the transmission seems to slip momentarily, then bumps back into the pull mode. It feels like there is slack in the drivetrain until it re-engages, or like the lockup torque converter momentarily releases until the computer has time to react to the accelerator positioner calling for more. One guy said the transmission is, at that point, between two gears... either trying to decide to downshift or to upshift, but you can feel the surge in rpm momentarily until it “decides” ...then bump and your off and running again. If I push the O/D button, it stops doing it. Anyone know what I can do? Because the dealer can't seem to get it to act up when they test drive it. It does it fairly regularly on me though.
Old Apr 13, 2012 | 03:47 PM
Beechkid's Avatar
Beechkid
Well, if you are driving say not over 40 mph when it occurs, that's likely normal, fyi- a speeds not exceeding 40 mph you are suppose to lock OD out.
Old Apr 13, 2012 | 06:03 PM
Lead Head's Avatar
Lead Head
No, you are not supposed to lock OD out when traveling under 40....You're only supposed to lock OD out when it starts hunting between 3rd and 4th while towing or hauling a heavy load.
It's probably IS momentarily unlocking the the converter, then locking back up. Canceling O/D probably keeps the converter locked up longer. Another possibility is that it's in 3rd, and shifting into 4th when you let off the pedal, then back into 3rd once you get back on. Automatics typically unlock converters between shifts, and when you let off the gas.
Old Apr 13, 2012 | 06:43 PM
Beechkid's Avatar
Beechkid
So much for the owners manual! That's exactly what it states almost word for word....just had this same discussion with my mother-in law, got both & my owners manual out, and let her read out loud both......if you also check with the tranny guys (ASE) online here and do a search, you will also find where regarding 4th gear engagement issues, it is caused in many cases excessive shifting between 3rd & 4th gear (my word paraphrasing) which I can even dig up pics of 4th gear engagement/actuator related component (retaining rings, etc.)
Old Apr 13, 2012 | 06:59 PM
Lead Head's Avatar
Lead Head
Here's what the manual says:
Drive is activated when the transmission control switch is pressed.
• This position allows for all forward gears except overdrive.
• O/D OFF lamp is illuminated.
• Provides engine braking.
• Use when driving conditions cause excessive shifting from O/D to
other gears
. Examples: city traffic, hilly terrain, heavy loads, trailer
towing and when engine braking is required.
No where does it say to lock out OD under 40. Only IF you get excessive hunting between OD and 3rd.
Walleye Hunter
Jun 12, 2017 08:32 AM
tomph
Oct 15, 2011 02:49 PM
true blue
Jul 28, 2011 05:23 PM
deemac
Jul 28, 2010 06:34 PM
Mark W. Ingalls
Oct 8, 2008 04:49 PM
