Ignition issues during starting
Old Jul 20, 2015 | 08:21 AM
candoo's Avatar
candoo
1966 F350 352.
I have replaced the 352 with a 390. While the truck was a 352 I replaced the coil with no issues, ran fine. I have now replaced the 352 with a warmed over 390 which has a MSD and coil. The issue I have is I tested all the wiring pre 390 install and found no issues. While trying to start the 390 this weekend i could not get it to run due to low volts at the coil (which i did test) Volts at the coil are 2.7 VDC. To get the 390 to start I jumper the coil during the starter operation and got it running. After the start up I checked the coil wire again during startup and got 12.7 VDC. STRANGE. No wiring changes by myself......Bad contacts? hidden ballast resistor? resistor wire?
Old Jul 20, 2015 | 08:29 AM
62fordF250's Avatar
62fordF250
Could be dirty ignition switch, starter solenoid terminals, or a grounding issue. I would start by cleaning up all of the engine and body grounds in the engine bay. Starters pull a lot of amperage and without enough clean metal-to-metal ground paths there won't be enough capacity to run everything at the same time.
Old Jul 20, 2015 | 08:55 AM
candoo's Avatar
candoo
I found a wiring diagram showing a resistor wire...All othe parts new and tested.
Old Jul 20, 2015 | 09:26 AM
62fordF250's Avatar
62fordF250
Nice looking 390.
The resistor wire should knock the engine running voltage to 6v at the coil. Starting voltage should be full battery voltage at the coil.
Start tracing the +coil wire looking for damage, or run a new one from the coil to wherever your diagram says it should go.
Old Jul 20, 2015 | 09:35 AM
candoo's Avatar
candoo
New coil literature states NO ballast or resistor to coil...ie full voltage for 8 cly. My thinking is to run new wire from coil + to ignition switch around resistor wire. Any special trick to remove ignition switch ?
Old Jul 20, 2015 | 10:21 AM
62fordF250's Avatar
62fordF250
Post #2
https://www.ford-trucks.com/forums/8...h-removal.html
Post #9
https://www.ford-trucks.com/forums/1...ut-no-key.html
Old Jul 20, 2015 | 01:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C0LF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37) / Obsolete ~ Available NOS and from auto parts stores.
61.49" long / Colored coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
Applications: 1960/70 ALL FoMoCo vehicles.
Note: In order to remove the ignition switch bezel, the ignition cylinder has to be removed from the switch...first.
Once the cylinder is removed, the bezel can be removed, the switch is now free of the dash and once it's removed from its hole in the dash, the ignition switch spacer will fall out onto the floor.
The spacer is located between the ignition switch and the backside of the dash. See 10A885 in this parts catalog pic.
Old Jul 21, 2015 | 08:10 AM
bluovl's Avatar
bluovl
Hello Candoo, please pardon my rough intro but I have been lurking here for a long time. If that distributor is an MSD "Ready to Run" model it requires a full 12 volts to work. You will need to bypass the resistor in your ignition wire. Symptoms are the engine will start when the key is in the start position and then die in the run position.
Maj spoons
38
Oct 11, 2017 06:23 AM
lpdcjr
Jan 2, 2015 05:40 PM
TFagerholm
17
Jun 8, 2009 05:26 PM
eclypseballoons
Electrical Systems/Wiring
May 22, 2008 07:29 PM
Randyb12
31
Feb 18, 2004 10:10 PM
