Clutch setup
Old Jul 21, 2015 | 08:03 AM
candoo's Avatar
candoo
Clutch setup
Installed clutch last night c/w linkage and throw out bearing. I am not sure how much tension should be on the clutch fork/throwout bearing at rest. Without any adjustment there is a small amount of pressure on the clutch and all seems OK. Center force dual friction and a NP435. Any guidlines ?
Old Jul 21, 2015 | 09:16 AM
Putt's Avatar
Putt
There should not be any pressure on the pressure plate fingers at all, you should have 1"-2" of free play at the pedal before it contacts the fingers on the pressure plate. If the T/O bearing is left in contact at all times it will cause it to fail in short order and could cause clutch slippage.
Old Jul 21, 2015 | 09:23 AM
candoo's Avatar
candoo
Looks like general guideline are approx 1/16 inch between throwout bearing and clutch.
I will see where the freeplay ends up.
flattie39
May 16, 2015 07:46 PM
Morris98
Dec 2, 2007 07:49 PM
basmith
Aug 3, 2003 05:08 PM
exploringnva
Jul 25, 2002 06:55 AM
AFD301
Jun 14, 2002 07:55 AM
