88 Alarm System help
Old Jul 19, 2015 | 02:54 PM
BLACKHAWK_1989's Avatar
BLACKHAWK_1989
i Got an 88 f150 custom Which i want To hook an Alarm up To When a door is opened and add extra switches To trigger for The tailgate. any help appreciated.
Old Jul 19, 2015 | 04:42 PM
bashby's Avatar
bashby
If I felt the need to put an alarm in an 88 F150 Id be moving to a better neighborhood.
Old Jul 20, 2015 | 09:23 PM
BLACKHAWK_1989
Its Not for The truck but for Whats in it. i have it Set up with a canopy and sleeper. there Are valuables that get left inside and i want To protect them The best i can. You all know How people can be if They See a vehicle off The road with Good **** in it un attended.
i was thinking of putting a dome switch in The tailgate and t it To The dome switch in door.
Old Jul 21, 2015 | 12:06 AM
BLACKHAWK_1989
OK, so my alarm is set up to bypass the dome light fuse and will sound if any light turns on or if the ignition is turned or if power is drawn from the DC port.
The alarm is a 2 wire siren with shock sensors, Ground & Hot.
How would I install a pin switch to trigger the alarm? Could I hook a tilt sensor to the red wire?
Old Jul 21, 2015 | 03:21 PM
BLACKHAWK_1989
The red wire is The siren
So The red wire is tapped in To The Blue 15 above it To get a constant Power feed. it is Set Where it will still work if The fuse blew. anything that sets The intermitter To close will Set it off. How would i go at adding a Pin switch To Do This?
Old Jul 21, 2015 | 03:37 PM
bashby's Avatar
bashby
What is an intermitter? What is a pin switch? I think nobody is responding to your post because it is not clear what you are trying to do. I am guessing you have a siren of some sort and are trying to make your own alarm system, but I am not sure.
Old Jul 21, 2015 | 06:53 PM
BLACKHAWK_1989
a Pin switch is like Whats in The door and turns dome light on When open. i Need Some sort of current To Set The Alarm off. Not sure How To hook up a switch To Do This tho.
Old Jul 21, 2015 | 08:08 PM
bashby's Avatar
bashby
Again.. are you trying to make your own alarm system?
Do you only have asiren from an alarm system?
Old Jul 24, 2015 | 07:50 PM
BLACKHAWK_1989
Its a siren with all The Alarm Features inside, Yes Its an Alarm. it monitors The voltage So all i Gotta Do is hook a switch in The back, but How Do i Do that without causing a short?
Like i said earlier, Its a 2 wire Syste and does Not gave a hood/trunk wire.
Old Aug 2, 2015 | 01:29 PM
BLACKHAWK_1989
i Figured it out, replaced a rubber bumper with a bronco rear Pin switch.
Old Aug 2, 2015 | 02:56 PM
bashby's Avatar
bashby
Still not sure what you are talking about, but where you tapped the fuse box for power....
you said it has power even with fuse removed. Put an inline fuse there before you burn your truck up.
pickerdd
Sep 14, 2017 04:27 PM
17 Oaks
6.7L Power Stroke Diesel
Mar 3, 2015 01:41 PM
iggy2
Sep 13, 2011 10:54 PM
eysham
Nov 22, 2007 02:27 AM
scacho
Electrical Systems/Wiring
Dec 10, 2005 04:12 PM
