AE Slides and Data
Old Jul 15, 2015 | 08:39 PM
Thomas White's Avatar
Thomas White
AE Slides and Data
Okay, since Monday, when I discovered My Snap-On Solus, Ultra, MTG2500, and Modus, The adjusted said I should have a Check by weeks end to pay off the Snap-On Man,
I have used my AutoEnginuity which has all the bundles from a few years back. Which to be honest, the controller has set in the top of my Box since because of stability issues.
Well, I had to get it working Monday Afternoon. I tried to get it to record on a Dell E6400 - No Go, Kept Freezing, next Was a Toughbook (2014) - No Go, would just shut the program down, 3rd Time was a Charm, Toughbook from like 1999 with Xp - Worked great!
So, here are my recoding's. I had to take a crash course on chart building with Excel, If anyone is interested, the original CSV File is: https://goo.gl/SGMZ1U
The Truck came in as the owner broke his EBPS off trying to clean the Tube. So, I put a Sensor and Tube in. He said he had a rough idle occasionally and I said I would do my best to get a Scantool. Otherwise he'd have to being it back next Monday.
The only anomaly I see is the EBPS is at 36 psig @ 3,400 RPM. The Spec is 34 psig @ 3,400 RPM'.
I did the Runs in Stock Mode. Actually I removed the Chip as often you can get interference . No other mods to the truck.
Old Jul 16, 2015 | 07:06 AM
Tugly's Avatar
Tugly
Things look pretty close to normal on the screen shots, but I'll download the data when I have more time and get a good look at it.
ultraranger
Nov 16, 2017 03:24 PM
MacD1976
Jan 8, 2015 10:12 AM
Deluxe06
18
Sep 20, 2010 09:01 AM
Adam0331
Mar 12, 2009 08:57 PM
Izzy351
26
Apr 28, 2008 03:43 PM
