Sponsored by: Auxito
AC problem
Old Jul 14, 2015 | 11:01 AM
acfeldman150's Avatar
acfeldman150
AC problem
Hi Guys,
I have a 2000 F150 with the 5.4. Where is the AC low pressure switch? I need to jump it so I can refill the Freon.
Old Jul 14, 2015 | 12:00 PM
projectSHO89's Avatar
projectSHO89
See the HVAC FAQs. That is one of them.
Old Jul 14, 2015 | 01:45 PM
steve(ill)'s Avatar
steve(ill)
You don't need to jump nothing. If you put a can into the low port, it will fill the entire system to 30-40 psi. Now start the truck and engage the air conditioner while putting in the second can. As long as the low side is over 25 psi, the compressor will run. If it kicks out, continue to dump in gas until the pressure builds up and compressor restarts.
Old Jul 14, 2015 | 01:58 PM
projectSHO89
Actually, it will pressurize the system up to the equalized pressure in the can.
Old Jul 14, 2015 | 08:45 PM
steve(ill)'s Avatar
steve(ill)
Exactly.. and that is normally around 30 psi. When the system is off, if you put on a gauge you will read about 100 psi on the LO side and 100 psi on the HI side on a properly filled system.... everything will equalize as SHO89 said. Just dump in a can, then start the motor and run the AC.
Old Jul 14, 2015 | 09:25 PM
projectSHO89
No, it's determined by the TEMPERATURE of the refrigerant in the can (or container). Consult a Pressure/Temperature chart for R134a for typical values.
ggenovez
1997 - 2003 F150
Jun 14, 2015 09:32 PM
norm9759
Sep 22, 2010 01:40 PM
Bioford
28
Aug 20, 2006 07:23 PM
Merlin509
Jun 8, 2005 06:09 AM
Luzer27
Jun 1, 2005 11:04 AM
