Door panel Pics
Old Jul 11, 2015 | 02:26 PM
Tank77's Avatar
Tank77
Door panel Pics
Hoping those out there who have done custom door panels can share some pics maybe some instructions on what they did..
Last week I took mine off, repainted and added all new factory clips etc but they just seem to be looser than what I want. Constantly have to smack them back in place..
I like the Diamond plate look but I want to retain the factory armrest and latches..
Any ideas would be nice..
Thanks guys
Old Jul 11, 2015 | 11:04 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Use the plastic longer GM push pins, not the Ford ones and NOT the metal ones.
You can notch cut the place the 2 bolts touch and hold the panel out, no worries the finger cup covers them. And you can also add 2" wide velcro, along the top and bottom.
You can also do a combo stock door panel and tread plate over lay.
Old Jul 12, 2015 | 06:19 AM
Bobird's Avatar
Bobird
I like the diamond plate/stock panel ,Might look nice painted satin black too.
Old Jul 12, 2015 | 07:58 AM
77&79F250's Avatar
77&79F250
You can get the aluminium tread plate in colors like black, red and blue. Not just solid painted looking, but more like a shade of those colors infused in the metal thru and anodizeation process? Or how ever you call it?
http://diamondlifegear.com/diamond-plate-aluminum.htm
Old Jul 12, 2015 | 01:20 PM
GeneGregory's Avatar
GeneGregory
Rich , Where do I get the right push pins to hold my door panels tight ? I was looking at the ones Dennis Carpenter sells and they look the same as the ones I had on my right door, the left door had different ones and it was loose and squeeked .
Gene
Old Jul 12, 2015 | 04:56 PM
77FordExp's Avatar
77FordExp
I made these door panels out of 1/2" birch plywood. The arm rest and speaker pod is made out of fiberglass. The panels are attached with screws with snaps. Covers were made to hide screws, one cover for the bottom and the long skinny cover at the top. I also used a couple of the speaker screws to hold the door panel. The door handle is made out of stainless steel.
Old Jul 12, 2015 | 05:15 PM
jas88's Avatar
jas88
I just cleaned and repainted my original door panels to match the 92-96 cloth seat I put in, it's more of a taupe color, so I got some plastic paint from Lowe's and painted em. Then, when I went to install them, I found the back part of the door panel where the clips go all busted up and most would not hold a clip anymore. I have seen people put screws thru the door panel and I thought that looked trashy, but I did not want to start all over with repop panels. I recently put a gauge pod in my '91, and it came with screws that had these little caps on them that you could paint to match. They look pretty nice so I went looking for those online. I found them at pro-dec.com, they are called "kappets" I think. Anyway, I bought em and put 4 screws in the panel, it turned out pretty nice, I think, and it was, most importantly, cheap:
Old Jul 12, 2015 | 06:46 PM
77&79F250's Avatar
77&79F250
I got mine at Auto Zone, in the fastener dept....
Old Jul 12, 2015 | 08:13 PM
GeneGregory
Rich do you recall the part number for the push pins ?
Old Jul 12, 2015 | 08:20 PM
77&79F250's Avatar
77&79F250
A pic is worth a 1000 words IMO.
Old Jul 12, 2015 | 08:35 PM
GeneGregory
IN this case more than a 1000 , Thank you , Rich
Old Jul 14, 2015 | 12:39 PM
Tank77's Avatar
Tank77
all great ideas thank you guys..
Old Jul 14, 2015 | 07:08 PM
paredneck33's Avatar
paredneck33
Great job on those door panels. They turn out great. They would look right at home in a resto mod truck too. Thanks for sharing.
c.l.nye
38
Nov 8, 2024 10:14 PM
GM4WALLS
20
Jun 10, 2018 07:04 AM
mudder460
Jun 2, 2016 05:26 PM
pumpdriver20
Jul 12, 2014 09:48 PM
Beastmaster
Jan 1, 2006 04:03 PM
