custom door panels? NEW PICS!!!
Old Jun 21, 2010 | 01:22 PM
c.l.nye's Avatar
c.l.nye
has any one built or modified their door panels? I am thinking of making a set for my truck and am looking for ideas and input. pics if you have any.
Old Jun 21, 2010 | 01:30 PM
650's Avatar
650
I do not have any pictures of it now but for my truck I am taking my black doorpanels, painting the fins silver, inserting the ranger woodgraing and painting the doorcups silver. It looks great so far. I,ll get a pic asap. I,ve also seen at shows where people get carpeting on their doors below the panels, and get the FORD letters engraved.
Old Jun 21, 2010 | 02:55 PM
EJ AZ's Avatar
EJ AZ
I would also be interested in seeing what you guys have done. Gonna do this too down the road.
Old Jun 21, 2010 | 03:02 PM
Heavy One Fifty's Avatar
Heavy One Fifty
Ive made them out of diamond plate and stainless sheets just using my oem door panel as a pattern in the past
Old Jun 21, 2010 | 05:48 PM
bobwires's Avatar
bobwires
I'll be making some soon. I'll post the project when I do. I'm opposed to using sheet metal for door panels - looks hokey. I'm a fiberglasser, so that's the route I'll take.
Old Jun 21, 2010 | 11:39 PM
c.l.nye's Avatar
c.l.nye
well here is what I have now. It is a modified stock piece. The speaker is up that high for two reasons,One it raises the sound field to a much better level and two it was going to interfere with my power window set up.The lower panel is a piece I made from 1/4" oak plywood and covered with auto carpet(matches the kick panels). I was thinking of making new panels out of either 1/4" cabnet plywood or hard board and molding in a speaker ring and window switches.
Old Jun 22, 2010 | 08:36 AM
mudder460's Avatar
mudder460
All I did was replace the original piece that was folding in the corners with diamond plate.
Old Jun 27, 2010 | 02:49 PM
c.l.nye's Avatar
c.l.nye
Ok,I have been a little busy but did manage to get started on my door panels. Decided I am going to retro fit 67-72 door handles and trim cups for a smooth look.Now I just need to find a set and mod. my latch setup. I have the panel cut out and am working on the lay out of the arm rest,window switches and speaker pod.If any one has a set of handles PM me. Thanks
Old Jun 28, 2010 | 12:47 AM
79 f-150 guy's Avatar
79 f-150 guy
hey i'm parting out a 1971 ford. so pm me if you need them handles.
Old Jul 3, 2010 | 07:34 PM
c.l.nye's Avatar
c.l.nye
well I finaly found the time to work on my door panels today. I got the driver side done.I am still trying to decide if I like it.LOL
It is all built from cabinet grade 1/4" plywood and solid shaped wood. They are all covered in real leather. Still not sure about the lighter color of the trim piece on the bottom.I also switched the window switches from 97 up to a late 80s style for ease of instalation.
Old Jul 4, 2010 | 07:09 AM
c.l.nye's Avatar
c.l.nye
no opinions? looking for some feed back, good or bad.
Old Jul 4, 2010 | 07:22 AM
Rumfather's Avatar
Rumfather
Hey C.L.NYE - I really like all things stock or close to it, so not a huge fan - BUT... for me it's a bit hard to get a sense of what you are trying to achieve just seeing the door by itself - how does it look in the context of the whole cab?
Personal preference would be less contrast so as the lower white panel doesn't stand out so much. Good on you for trying though - I'm putting up with originals which are cracked, rattling and the wrong colour...
Old Jul 4, 2010 | 07:40 AM
a1bummer's Avatar
a1bummer
I like the diamond plate aluminum idea also. I'm not sure if I wanted to make the whole panel out of it or just make some inserts to dress up the existing panel as some of you have done. But I like the looks of it. I had also thought that maybe some accents on the dash would look good to go with it and may making the instrument cluster out of it to match, might look spiffy as well.
Old Jul 4, 2010 | 08:39 AM
ky79's Avatar
ky79
C.l.nye I like it nice and clean. I would like to know how you made your door latch. I need to do something similer as my door panals are busted to pieces.
Old Jul 4, 2010 | 09:49 AM
650's Avatar
650
If that bottom part of the panel was black instead of grey, I think it would look better. If you could find out how to I would try and see if you could put FORD letters into the bottom somehow. It might look cool. Another idea might be if your truck is two tone you could try and use those colors in the panel if you already havent. I myself like the origonal doorpanels like this one of mine.
Note: The door itself is gonna be black when done.
Good luck
