Radiator Support Replacement on 2003 Expedition
Old Nov 4, 2015 | 06:42 PM
wrench2nr's Avatar
wrench2nr
I got my rocker thru LKQ. About $55 per side.
Old Nov 15, 2015 | 05:56 AM
onoahimahi's Avatar
onoahimahi
Hi - I just discovered that my 05 EB Expedition has this problem too
Mine is just about as bad as the original poster's was. (I'm not ready to tackle this repair but would like to get another year out of this truck if possible.)
My question is about the function of this Radiator Support part - does it do more than just support the radiator? That is, is it keeping the whole front end sheet metal parts like the fenders from sagging? Or is the chassis rigid enough so that it will not sag when the radiator support fails at the lower corners where it attaches to the frame? The rest of the support is solid - the problem is confined to the bottom corners.
At the moment my radiator seems solid, and I suspect I could kludge some kind of support to make sure in place (for example, by attaching some kind of straps to the non-rotted portions of the radiator support.) However, this kind of repair would do nothing for supporting the front-end sheet-metal parts.
Thanks,
-Scott
Pikachu
May 19, 2017 01:15 PM
ihcc104
Jun 21, 2016 09:41 AM
abe
Jan 16, 2015 11:29 PM
Drewski 2
Mar 26, 2013 04:12 PM
davewave649
Oct 7, 2012 02:40 PM
