Radiator Support Replacement on 2003 Expedition
Anyway, the worst place I need to immediately care for is the radiator support. As you can see, the A/C condenser on the drivers side has fallen out the bottom and rests on the support bracket. Plus, as luck would have it, the A/C recently stopped working too so no big loss if I need to disconnect some lines now.
While I have read and seen pictures on it I have not seen an associated good write up with steps and advice. I'd like to take this job on myself. It seems to be mostly labor. Looking for some advice with steps and direction on this. I have already purchased a new third party radiator support (4L1Z16138BA or FO1225133). I see there are spot welds to drill out and such but I am more concerned with what I need to otherwise disassemble.
What are thoughts on using large cherry rivets to put the new support back in along with something like 3M panel bonding adhesive instead of welding?
http://3mcollision.com/products/adhe...ive-08115.html
Here are some pictures:
I didn't realize you could use the specialty glue instead of weld.
I'll give that a try. Currently I haven't done NY thing but order the support. I got it through Amazon.com for 120.93. No shipping cost. It will be at my door around Aug 6th. Then the fun begins.
I'll try to post something on what I find.
Thanks.
RADIATOR SUPPORT for 2006 Ford Expedition|5L1Z-16138-A
I stiil have yet to start the repare. I just received the part yesterday. I plan to get started next week.
I'll put a post together a s I do the work.
I got side tracked when my rear brake line burst and now changing brake lines is taking priority. Then of course I find my parking brake is seized and I need to replace much of that stuff as well. Brakes come first!
I still think this was a very poor design on Fords part where they know trucks get used in winter regions where there is salt on the roadways. This would never be a problem with a better sloping design for drainage, a simple plastic diverter underneath to prevent salt from getting kicked up in that area, and a thicker radiator support NOT stamped with multiple thin sheets of steel where salt gets in between and rusts it out. I also think the factory steel uncoated brake lines were a joke and cost me a ton of work to fix as well.
That said, it is a nice feeling not to have to worry about it anymore. I have new brake lines all around, new flex lines, new master cylinder, new brakes, new rotors, a nice new radiator support with a new radiator too, and new transmission cooler lines. If this thing gets in a wreck I'm going to be pissed because I just spent a lot of time and money on it. Probably half what it is worth on the market at this point. Still love it though and plan to keep it a long time. I haven't even hit 80,000 miles yet so it should have plenty of life left and with new trucks around $40,000 and up I think it is still wise to keep this thing. Just need to fix up some other rust and paint issues before there is lasting damage and perforation.
Long story short I got 2000.00 for it towards a '13 f150 sepercrew 3.5 ecoboost. Do I miss the EB Expy? Not one bit.
For anyone else concerned about spot welds, Harbor Freight sells surprisingly decent spot weld drill bits for about $5. You might go through 2 bits to drill out this support and it isn't that hard. I'd think it easier to replace the whole thing than trying to match up and weld cut pieces. At least that was my plan before I paid to have it done.
Congrats on your new truck and nice choice! My Expedition was giving me such fits I lost some confidence in it for a bit and bought a new vehicle too. 2015 Mustang Ecoboost is surprisingly affordable and fun to scoot around in. Glad to have the Expedition for the winter and Home Depot runs.
