Overall Help!
Old Aug 14, 2015 | 12:11 AM
  #31
96F250SD's Avatar
96F250SD
I will have to look into a manual... the interior is for brake controllers, but the rear is... a 6 pin plug hanging below my bumper. It has 2 plugs on the other end going into my factory harness. No wires are chewed or spliced, all original lookin on the 2 plug end... the colors are... 14 GA blue, black w/ green tracer, and either orange or red I cannot tell, out of one plug. The other plug has 4 wires. They are, 18 ga, green, yellow, black w/ white tracer, and a 14 GA white wire. These all plug and played... trying to wire up a standard 7 pin towing hook up.
Old Aug 14, 2015 | 09:23 AM
  #32
farmert's Avatar
farmert
I'm going from memory so it might be a little fuzzy. The blue is for trailer brakes, black w/green trailer back up light, red hot to trailer charge. On the other, green right turn, yellow left turn, black w/ white is trailer marker and white is ground. Check with a test light to make sure I'm remembering right.
Old Aug 14, 2015 | 08:09 PM
  #33
96F250SD's Avatar
96F250SD
That helps more than anything I found yet... the new plug from auto zone has a dam stripped holes from the screws even before I started. Dam plastic bs you can't even find metal ones any more...
Old Aug 14, 2015 | 08:12 PM
  #34
fordman67's Avatar
fordman67
Do a search.iirc there is a standard wiring plan for it.
sand_fiend
Nov 22, 2011 05:17 PM
riverrat41
16
Sep 15, 2009 11:39 AM
flaboy63
Aug 2, 2008 09:16 AM
scatgo
Feb 18, 2008 11:36 PM
enduringexplorer
Aftermarket Products
Mar 8, 2007 02:48 PM
