302 vs 351
Old Jul 9, 2015 | 12:57 PM
Four.on.the.floor's Avatar
Four.on.the.floor
okay i will read into that tonight thanks
Old Jul 9, 2015 | 05:01 PM
Four.on.the.floor
my truck with the 302 has the dual sump oil pan with two plugs. do you think it might have the oil extension and equipment already on it? could the parts swap over ?
Old Jul 17, 2015 | 06:12 PM
Eightyfive Flareside's Avatar
A little off topic, but for my own info.
If you used gt40p heads on the 351 would there be any reason you couldn't maintain your stock efi system?
Old Jul 17, 2015 | 08:48 PM
Franklin2's Avatar
Franklin2
The dual sump pans do have a extension on them. I don't know if it will work ok with a rear sump though, never eyeballed it or tried it.
Old Jul 17, 2015 | 08:52 PM
Franklin2's Avatar
Franklin2
Can you run stock exhaust manifolds on the gt40p heads? You will need to mount the oxygen sensors somehow if you use something different.
Four.on.the.floor
Engine Swaps
Jul 11, 2015 12:56 PM
smoke n tires
Jan 12, 2009 07:58 AM
FLICK
Apr 11, 2005 04:44 AM
bigblocksix
48
Jul 20, 2004 11:59 PM
papaul
Oct 22, 2000 03:42 AM
