P0193 code
Old Jul 8, 2015 | 07:28 PM
tm-pmg's Avatar
tm-pmg
P0193 code
I went to the dealer with a P0193 and he said to me that the left fuel rail needed to be remplace because it have a little welded hole that block some fuel line when i need throttle !! So i remplace the fuel rail and the truck be OK for two days after this it begin to stall in 1 and 2 with the engine light on.........
I disconnect all the connector from the PCM and disconnect battery to reset the trouble code. It runs number one, two days but the P0193 reappear with the battery light on....
Someone had the same problem and know how to repair the trouble? I thing it's a wire somewhere was ground or broken but I don't know where the Frp is on the engine
Thanks!
PGM
Old Jul 8, 2015 | 07:46 PM
senix's Avatar
senix
If the truck is under warranty I would go to another dealer that knows how to fix the truck.
Old Jul 11, 2015 | 10:32 AM
tm-pmg's Avatar
tm-pmg
No warranty I think is the FRP sensor or his circuit in trouble. Where is the FRP sensor, i'm not sure!
PGM
Old Jul 11, 2015 | 06:38 PM
Just Strokin's Avatar
Just Strokin
see if this obdii helps...this is for 2011...you didn't say what year your truck
http://www.motorcraftservice.com/vdi...DOBDSM1101.pdf
if another year, go here and select
https://www.motorcraftservice.com/vd...&menuIndex1=10
Old Jul 11, 2015 | 07:29 PM
vloney's Avatar
vloney
PGM
FRP sensor is on the left fuel rail. FRP is on the front, Pressure regulator valve is at the rear.
Old Jul 13, 2015 | 01:33 PM
tm-pmg's Avatar
tm-pmg
It's the connection on the ECM it's loose!!
CPTMidnight
6.7L Power Stroke Diesel
18
May 16, 2019 05:17 AM
js139
Jan 24, 2018 07:37 PM
bradtm16
6.4L Power Stroke Diesel
21
Apr 29, 2016 11:48 PM
KrAzYKARL
2004 - 2008 F150
Sep 4, 2011 07:26 PM
tome
Jan 20, 2004 08:35 PM
