Power steering conversion
Old Jul 7, 2015 | 07:52 PM
Caveman2851's Avatar
Caveman2851
Where is the best place to purchase all that is required to do a Toyota steering box install including all linkage? I have been reading some posts on this and other sites that a couple of places that were previously listed are now rip off artists.
Old Jul 8, 2015 | 07:18 AM
ibcruzin's Avatar
ibcruzin
I bought the pitman arm and heavy duty tie rod from CPP. I have not installed the parts yet, but they appear to be good quality, the prices seemed fair and I have not heard anything bad about them. Here's a link:
Classic Car and Truck Brake, Steering and Suspension Parts
Old Jul 8, 2015 | 08:15 AM
Caveman2851
Did you have to wait long for the parts you ordered? They are one of the companies that have a few red flags on service. They also are listed by the BBB as having a tripple C rating. They do seem to have all I need but I was worried about being taken.
Old Jul 9, 2015 | 09:11 AM
greenmachine55's Avatar
greenmachine55
Another place is Mid Fifties to look into.
Old Jul 13, 2015 | 07:06 AM
ibcruzin's Avatar
ibcruzin
I received my parts in normal ground shipping time.
Old Jul 19, 2015 | 02:32 AM
59 shorty's Avatar
59 shorty
Anyone figured out a way to make that "ball and socket" pitman arm work with the "tapered"drag link our trucks use? Have all the parts gathered up to convert the 59 over only need a proper pitman .Am I missing something? What have you guys done? Mark
Old Jul 19, 2015 | 08:32 PM
mgargiullo's Avatar
mgargiullo
I bought a power steering kit from CPP. Great place, I'd purchase from them again.
Old Jul 20, 2015 | 10:46 PM
Caveman2851
OK great thanks.
Old Jul 22, 2015 | 08:07 PM
kujo3692's Avatar
kujo3692
CPP
I posted on the other steering box thread, but here i go again...I used a CPP kit and works great...if you have a factory 4WD, your steering shaft wont work with the rag joint they supply in the kit...you will need one from a 2wd (smaller diameter)..even with a big block, the box clears and fit and finish is top quality
In other news...i swapped to a Dana 60 front axle and can no longer use the factory drag link....building my own from a kit purchased from WFO concepts...just have to ream the pitman arm that came in the CPP kit and axle steering arm to match the taper on the tie rod ends that are used in the WFO kit
Old Jul 31, 2015 | 03:19 PM
greenmachine55
Caveman, where did you buy your power steering setup? Have you started installing it yet and have you run into any problems?
I ordered mine through Mid Fifties and will receive it on Monday. Saturday I will start taking my steering out.
Old Aug 2, 2015 | 11:14 AM
Caveman2851
I'm going to get my kit from Mid Fifties also just need to get some cash together. I just picked up my new/used front axle yesterday and need to wait a bit because I'm on a tight budget. The front axle wasn't what I expected when I got there. I thought I was going to get a dana 44 low pinion from a 1978-79 f250 but it was actually a high pinion from a highboy. Hope it works and clears everything with the 300 six engine I plane on installing.
Old Aug 14, 2015 | 08:38 AM
Byrd.Dog's Avatar
Byrd.Dog
Do you still have the steering arm off your 44? Mine has been welded to the bolts that hold it on, so I'm probably gonna destroy it trying to get it off(need to replace king pins & u-joints).
palehorse13
20
Jun 28, 2012 12:36 PM
highboyluver1923
Jan 28, 2010 07:10 PM
olfordsnstone
Dec 23, 2004 01:39 AM
lilpig88
Feb 10, 2004 10:39 AM
Ringmaster
May 4, 2002 12:16 PM
