Dash/gauges problems
Old Jul 4, 2015 | 05:49 PM
NativeDescent's Avatar
NativeDescent
My 1994 f150 xl is having dashboard malfunctions, the fuel gauge is pegged at full on both tanks, and battery voltage is pegged well below 8 volts, as well as intermittently the light for the brights doesn't come on, and the check engine light doesn't come on while the truck is in the on position on the ignition but engine off, and the battery light stays on when in the on position but engine off. Could all of these problems happening at the same time be from a fuse? Bad connections on the back of the dash? Should I remove the instrument cluster and clean and re-solder all the connection? Anyone else have this problem?
Old Jul 4, 2015 | 08:09 PM
subford's Avatar
subford
Sounds like a bad body ground behind the battery.
Did you replace the ground battery cable and not run a heavy ground wire to the body?
Old Jul 6, 2015 | 11:59 PM
NativeDescent
I did not replace the battery ground, but I don't think that's the problem as its on the two gauges not working and the CEL not staying on when the ignition is in the on position. I do plan on replacing the battery cables though so I may try replacing them at the same time as my dash, as I wish to find a factory tach instrument cluster to replace mine with
Old Jul 7, 2015 | 07:01 AM
subford's Avatar
subford
The fuel gauge pegged at full mark on both tanks says the fuel gauge circuit is open to ground. Both fuel tank gauge sending units are grounded at the drivers side (Left side ) radiator support at G100 (image below). G100 is at ground level because of the body ground at G101 in the post above.
G100:
The Voltage meter is grounded at G200.
G200 is at ground level because of the body ground at G101 in the post above.
G200:
The Hi Beam Indicator is grounded at G201.
G201 is at ground level because of the body ground at G101 in the post above.
G201:
The PCM Computer for the check engine light is grounded at G101 in the post above and at G104.
G104 is at ground level because of the body ground at G101 in the post above.
G104:
Old Jul 8, 2015 | 10:37 PM
tesia1971's Avatar
tesia1971
hi, does this works on a 1992 F-350 Diesel?
Old Jul 9, 2015 | 07:22 AM
subford's Avatar
subford
G101, G104, G200 & G201 are in the same place but G100 is in a different location by the drivers side head light.
G104 is a ground for your TECA and the TECA is also grounded at G101.
G100 is also the the ground for your fuel gauge sender.
G201 is the ground for the fuel tank selector switch as the fuel tank selector switch passes the ground through itself for the motor in the fuel tank selector valve.
G101 is also your body ground and a ground for other items such as the low vacuum switch.
Old Jul 9, 2015 | 07:01 PM
tesia1971's Avatar
tesia1971
Thanks subford, today I realize I don't have a slosh module, or whatever it's called, it's just empty, could that be the problem? is so, is there a work around?
Old Jul 9, 2015 | 07:43 PM
subford's Avatar
subford
As long as the traces are not cut that go into the hole then the cluster should not have a slosh module.
Slosh modules are used in the vans an large RV's.
Most if not all pick-ups do not have slosh modules.
Old Jul 9, 2015 | 08:29 PM
tesia1971's Avatar
tesia1971
I see, thanks for your time.
Old Jul 10, 2015 | 08:45 PM
NativeDescent
Turned out to be a blown fuse, but thanks for the help!
Old Jul 13, 2015 | 03:12 PM
NativeDescent
Now the fuse keeps repeatedly melting, third time in two days....
Magnum3672
16
Jul 9, 2019 09:07 AM
CustomHD
Oct 4, 2018 06:06 PM
Loganwolf
Apr 4, 2016 07:39 AM
LARIAT 85
Mar 14, 2016 03:45 PM
89Bulldog
1983 - 2012 Ranger & B-Series
Jul 28, 2010 09:01 PM
