Roving ground problem
Old Apr 4, 2016 | 06:00 AM
Loganwolf's Avatar
Loganwolf
I have a 1995 F150 and I seem to be having a ground problem. Every once in a while one of my windows will not go up or down and every so often I get a fault 53 I believe is the number for the airbag system stating one of the crash sensors on the front is not seeing ground. The reason I think both are related is because I have checked the windows when they won't work and I have power on both sides of the motor. I checked the ground wire from the fender to the battery and the one to the block and both seem to be good. If the one from the fender to the battery is the ground for the whole body the wire seems a bit small. Any ideas where to look? Like I said the problems are not always there and both Windows don't go out together either.
Old Apr 4, 2016 | 07:39 AM
subford's Avatar
subford
The windows are grounded at G201.
The crash sensors on the front are grounded by their mounting to body.
The air bag module is grounded at G200.
The Body ground:
G200:
G201:
Magnum3672
16
Jul 9, 2019 09:07 AM
CustomHD
Oct 4, 2018 06:06 PM
LARIAT 85
Mar 14, 2016 03:45 PM
NativeDescent
Jul 13, 2015 03:12 PM
SuperDutyScaler
18
Jul 31, 2010 12:27 PM
