AC Compressor Changeout
Old Jul 7, 2015 | 07:07 AM
Supercab's Avatar
Supercab
Wink
Same compressor, same gap, just in the Ranger just might need a clutch hold tool to remove the bolt.
https://www.ford-trucks.com/forums/1...lutch-gap.html
Old Jul 7, 2015 | 02:31 PM
Norsegod127's Avatar
Norsegod127
Ok so I got the Refrig, I was reading online and I heard that the AC compressor needs to be on which I knew but... Is it okay if I add it with my AC compressor clutch engaging and disengaging like in the video that I posted?
Old Jul 7, 2015 | 10:49 PM
wtroger's Avatar
wtroger
It will work but take longer as the refrigerant goes into the system the longer the compressor clutch stays engaged.
Old Jul 8, 2015 | 02:51 PM
Norsegod127
well, all I can say is... the slot did not fit on the low pressure slot. by any chance is there is a attachment that will fit over the original slot that will fit. Did a quick look online and theres something called a retrofit valve, would that fix the problem.
Amazon.com: Interdynamics MAC-134 EZ Chill Refrigerant Refill with Charging Hose and Gauge - 18 oz.: Automotive Amazon.com: Interdynamics MAC-134 EZ Chill Refrigerant Refill with Charging Hose and Gauge - 18 oz.: Automotive
Thats the product I got ^.
Unforantly there is no return for this item. So I need to find a way or Im out of $30 with no accomplishment.
Old Jul 8, 2015 | 03:25 PM
wtroger's Avatar
wtroger
1995 ranger should be an r134a system the small quick connector low pressure will be around the drier area the large quick qucik connector will be around the condenser front of truck. Your third picture shows the correct fitting setting on top of the receiver drier.
Old Jul 8, 2015 | 03:41 PM
Norsegod127
yah I tried it on the L Pressure the H is near the battery. Not sure why it isnt fitting but Im gonna try it tomorrow again.
Old Jul 8, 2015 | 03:47 PM
wtroger's Avatar
wtroger
It is the black cap setting on top of the black round drier with the pressure switch teed off of it. you should to be able to just push the connector on
Old Jul 8, 2015 | 04:03 PM
Norsegod127
Yeah that is the one I tried, doesnt connect fully. Seems like the refrigerant kit nosil doesnt go down far enough.
Old Jul 9, 2015 | 07:34 AM
exranger06's Avatar
exranger06
I had the same problem on my 94 Explorer. It had an aftermarket accumulator on it and I just could not get the hose connected to the low pressure service port for some reason (yes, it was a standard R134a port). I ended up installing a new accumulator and the hose connected to it no problem. I have no idea how the shop that charged it last was able to do so.
Old Jul 9, 2015 | 11:49 AM
Norsegod127
GREAT... I would love to change out the accumulator myself but I really dont feel like flush a system because I have no idea how to do that and I dont feel safe doing it. And im not gonna bring it to a mechanic because I dont have the money haha so i guess ill be having no AC until I get a new truck next year.
By the way do you know if they make a connector that scews onto the existing low pressure port like a extender?
Old Jul 10, 2015 | 03:57 PM
69issofine's Avatar
69issofine
my a/c compressor died before i got the truck,the pully turns but the compressor is seized i would like to know where you found a compressor for 100 bucks all the ones i have seen were north of 200 plus the reciever and orfice tube and the freone
Old Jul 10, 2015 | 07:13 PM
Norsegod127
Old Jul 11, 2015 | 07:48 PM
  #28
69issofine's Avatar
69issofine
wow thanks
jake22si
1997 - 2003 F150
Jun 28, 2015 09:04 AM
wheelie31
Jun 20, 2010 10:36 PM
Psycho Sasquatch
Aug 31, 2007 11:55 AM
madfinn
Mar 31, 2004 10:32 PM
