New Intake Manifold and Carb
I have a '79 F150 Custom with a stock 351M motor and stock 2 barrel carb. I want to put on a new Edelbrock intake manifold and carb. I'm wondering if I can put on a 4 barrel carb and eliminate the EGR valve? I'm very green to this whole thing so please dumb it down as much as possible
My personal opinion, is nothing smaller than 2.5inch exhaust, I have dual 3 inch for my 347. 3 inch if it will be crush bends and free flowing mufflers(read- no flowmasters). Coupled with a nice set of headers. If you plan to keep the motor with a re-build in the future then virtually anything you get for it aside from say pushrods can be looked at as collecting parts for the re-build.
What's your goal? Just to get it cold-starting better? Proper carb tuning (with a rebuild if necessary) can do that. More power? A carb alone isn't going to buy you much of anything. As HIO says, the exhaust side is more of a restriction, but even with that addressed, the heads are likely to be a choke point that prevents you from taking advantage of a bigger carburetor.
The main goal is to make it a reliable daily driver for now. I'd like to keep doing little things to it as time goes by to make it a rolling work of art while keeping the matching numbers. Right now it's all original with only 61,500 miles. I'll start with the exhaust and a carb rebuild and go from there. Any other suggestions? Basically if one of you guys bought this truck after it had only been driven 400 miles in 7 years what are the things you would do?
sweetlou1
17
03-17-2013 08:18 PM
truckman79
09-13-2003 09:38 PM
