Sponsored by: Auxito
New Code today?
Old Jun 30, 2015 | 02:13 PM
BFTUFF's Avatar
BFTUFF
New Code today?
Just started the truck after not running for a few weeks and drove around fine. Looked down and suddenly a CEL was indicated. Checked it with my Edge Evolution diagnostic mode and Code P0161 came up 2nd bank downstream heater circuit fault. What do you think guys before I bring it into the dealership?
I've also have an exhaust leak in the right passenger side exhaust manifold for about the last year. I've been waiting to install my newer 03' used engine when time and funds permit.
Old Jun 30, 2015 | 02:53 PM
projectSHO89's Avatar
projectSHO89
Check the wiring for the downstream sensor on the passenger side for damage. Inspect/reseat the connector. Reset PCM and retest.
If it still fails, swap downstream sensors, reset PCM and retest.
If the fault code moves to a P0141, the sensor now on the driver's side is bad (heater fault). If it stays a P0161, there's a wiring or heater fault.
This, most likely, is a $50 DIY repair job unless there are complications.
Old Jun 30, 2015 | 11:17 PM
BFTUFF's Avatar
BFTUFF
If I get the time, I'll do that. I've got my Mom in the Hosp. right now in bad shape and I've been by the phone waiting for news. I suppose Bosch is the best for sensors should I need one? Could that exhaust manifold leak have anything to do with it?
Old Jul 1, 2015 | 06:29 AM
projectSHO89
Bosch sensors are fine. If the exhaust leak caused the wiring harness to be damaged, then yes. Otherwise, no.
Best of luck with your mom's health condition.
Bluegrass 7
1997 - 2003 F150
Jan 27, 2018 11:41 PM
gaphantom
1983 - 2012 Ranger & B-Series
Jul 2, 2008 09:54 AM
cdj98f150
1997 - 2003 F150
Feb 20, 2006 02:40 PM
crawdad
Jan 27, 2006 10:27 PM
chiefcw
Jul 2, 2003 10:08 AM
