P0153 Error code
Old Jun 30, 2008 | 10:27 PM
gaphantom's Avatar
gaphantom
P0153 Error code
Have 1997 Ranger 3.0 keep getting P0153 code. I have replaced the H02 senors but still getting same error code
Old Jul 1, 2008 | 07:36 AM
ranger88a's Avatar
ranger88a
The code is for the left bank upstream 02. This is a slow responce code. Can be due to air leaks on the exhaust, fuel or air issue on the left bank, heater circuit problem for the 02. Check for an exhaust leak, check the maf sensor (although this usually sets lean codes) for contamination, I would also check the wiring to the 02 and see if all wires check good. Hope this helps.
Old Jul 1, 2008 | 10:45 PM
gaphantom's Avatar
gaphantom
I replaced the HO2 sensor on the passagnger side, before the catalytic converter. Is this the location for HO2-21?
Old Jul 2, 2008 | 12:59 AM
87 XLT's Avatar
87 XLT
P0153 is upstream drivers side.
Old Jul 2, 2008 | 09:54 AM
Bear River's Avatar
Bear River
Former ******
Slow response code means the sensors is just shot, not from air leaks or anything. I have never seen and O2 sensor set a code for slow response and end up having another problem elsewhere. I have seen lean or rich codes be caused by other problems, but never slow response. Those sensors should be replaced every 100,000 miles or so.
gatorboy
2004 - 2008 F150
Nov 16, 2008 05:02 PM
Fordfrog206
2004 - 2008 F150
Feb 14, 2008 10:29 PM
njxlt
Jul 31, 2007 05:27 PM
rpm1969
1997 - 2003 F150
Feb 11, 2004 08:19 AM
