f150 5.0 code 172
Old Jul 2, 2003 | 09:37 AM
chiefcw's Avatar
chiefcw
f150 5.0 code 172
The check engine light comes on after about 5 miles driving at hwy speeds. Stored code is 172 (o2 sensor lean). KOEO test shows pass (111). Light will go out and come back on by itself while driving. I found a crack in the pass side exhaust manifold and tried patching it with JB weld. The code still sets like clockwork after 5 miles. Does anyone think that the crack is causing the 172 code or should I look else where. This is the only code that is set. Truck runs fine and doesn't appear to be running rich - tailpipe is clean, no black smoke. It is a 1991 f150 5.0l auto,a/c. Any help would be appreciated.
Old Jul 2, 2003 | 10:03 AM
steve83's Avatar
steve83
f150 5.0 code 172
If you found one crack, you could have several more. An exhaust leak can cause a lean reading, but you need to do more diagnosis: is there a vacuum leak? Is the oxygen sensor (HEGO) good? Is the wiring harness damaged? The Haynes manual tells how to check all that & more.
Old Jul 2, 2003 | 10:08 AM
chiefcw's Avatar
chiefcw
f150 5.0 code 172
I checked vacuum hoses and connections and look ok. O2 sensor was replaced about 3 months ago. I check for other cracks and did find that the crack extended to the back side of the manifold. I will probably just replace it, don't believe the JB weld will fix it good enough.
