Sponsored by: Auxito
o2 sensor code
Old Feb 17, 2006 | 10:14 AM
cdj98f150's Avatar
cdj98f150
Question o2 sensor code
i have a 98 5.4 f150 4x4 the cel came on and the code is p0155(upstream heated o2 sensor heater circuit fault) bank 2, i was told that that was bank 2 sensor 1, is this the driver or passenger side sensor, first or second from exhaust manifold??
Old Feb 17, 2006 | 10:22 AM
Jeffman's Avatar
Jeffman
It s the passenger side and I think the first one from the manifold.
The link below is for another code but explains the location.
http://www.obd-codes.com/trouble_cod...2-sensor-1.php
Old Feb 18, 2006 | 08:20 AM
projectSHO89's Avatar
projectSHO89
Bank 2 is the driver's side, not the passenger side. Upstream means the one closest to the engine upstream of the cat.
Check the sensor's heater with an ohmmeter before replacing it. Sometimes it's just a connector that needs to be reseated. If the heater in the sensor is intact and the code reoccurs, then there is either a wiring harness fault or a fault in the PCM. Consult the diagnostic procedure int eh PCED for exact steps to check.
Steve
Old Feb 20, 2006 | 01:38 PM
Jeffman's Avatar
Jeffman
So the information on the link above is a misprint?
BANK1 = left side facing the front of the vehicle
BANK2 = right side facing the front of the vehicle
--jpn
Old Feb 20, 2006 | 02:40 PM
projectSHO89
--jpn
The information in my previous post is correct.
Therefore, if that site has differing information, it is incorrect.
Steve
