Adjust AOD Shift point
Old Jul 30, 2003 | 12:30 PM
medicpg's Avatar
medicpg
My AOD Transmission seems to shift good into first, but then seems to go into 2nd and 3rd gear a little early. I know I have to adjust the TV kickdown, but does anyone know if I need to increase presure, or decrease? Does anyone know the RPM Range it should shift?
Old Jul 30, 2003 | 09:30 PM
rclarke's Avatar
rclarke
An increase in pressure will make the shifts later and harder. If you are using a pressure gauge and the procedure in Ford shop manuals try setting the pressure at about 40psi, I had good luck with that pressure on pickups and police cars when I was working in a Ford dealership.
Old Jul 31, 2003 | 04:17 AM
medicpg's Avatar
medicpg
I was told 35 psi was max, but that doesnt appear to work well. I am just afraid to damage the tranny
Old Jul 31, 2003 | 05:02 PM
rclarke's Avatar
rclarke
Actually high pressure won't hurt the transmission as shifts will be firmer with less slippage. Low pressure is death on transmissions. Thats why on electronic controlled transmissions, failure mode is maximum pressure with very hard shifts.
Old Aug 1, 2003 | 04:51 PM
javi2001's Avatar
javi2001
Rclarke: Do you remember whats was the external diammeter of the original Ford Tool used to setup that pressure? I had manual, and I know the procedure, but I couldn't get the Ford tools needed.
My AOD use TV Cable, not TV linkage. I6 engine+carburetor+AOD
Regards;
Old Aug 1, 2003 | 08:06 PM
rclarke's Avatar
rclarke
Seems to me it might be 9/32". In the dealership I always had the Ford tool so I didn't have to worry about the actual measurement.
Old Aug 2, 2003 | 06:17 PM
javi2001's Avatar
javi2001
Ok. I'll try this size.
And I'll try 40 psi...
Thanks.
Grease & Gravel
19
Jan 19, 2025 11:27 AM
51dueller
23
Jul 16, 2016 03:40 PM
schoo
May 31, 2016 09:10 AM
broncobasher
May 28, 2004 08:45 PM
ksvtwin
May 17, 2004 12:43 PM
