AOD OD shift point
I noticed on the adjustment tutorial that you are supposed to have it in 3rd while driving and to adjust it until kickdown is at 45.....so is it supposed to kick into 3rd at 45 or OD at 45
Be careful and make sure it's correct. Shifting a little harsh is better than too soft. And the factory is usually going to set it so it shifts early to pass epa mileage requirements. They want it in OD as quickly as possible.
Too little pressure, or too much pressure, and you will ruin the trans fairly quickly.
But, it is achieved by holding the throttle wide open, and adjusting the linkages to have the TV lever at maximum travel as well. Now in theory, this should also mean that when at idle, there is no pressure on the TV lever.
Minor adjustments either way from there are OK. But it needs to be as close to that as possible.
you can't know something before you learn it. I have never brought a vehicle to a mechanic in my life...I always figure out how to fix everything by asking other people or researching online.
So, go get that tranny adjusted! Haha
At moderate throttle, you should feel a positive shift from 1st to 2nd gear. 2nd to 3rd will always be a little bit softer, and 3rd to overdrive will be a little soft as well.
If you don't have a pressure gauge, here is a test you can do to see if your TV pressure is correct. Drive your vehicle so that RPMs stay at 1500 RPM, and observe your shift point speeds. If you have a 5.0/302 engine with 3.55 gears, this is where your AOD *should* shift:
1 - 2 = 15 MPH
2 - 3 = 25 MPH
3 - 4 = 45 MPH
If your AOD shifts earlier or later than that, you should adjust the TV rod until it matches the above shift points. If TV pressure is too low, the AOD will shift early with very soft, lazy shifts. This is bad for the transmission. If TV pressure is too high, the AOD will shift later and harsher and overdrive will either not come in all or you will have to let off the gas completely for it to engage. It will usually "clunk" into overdrive if the pressure is too high.
When you have the shift points correct, here is another test. Drive the truck normally, and as soon as you feel the AOD shift into 2nd gear, FLOOR the gas pedal. Your AOD *should* immediately downshift to first gear. Next, with the transmission in "D", floor the gas pedal when your truck reaches 45 MPH. Your AOD *should* immediately downshift to 2nd gear.
If your truck passes all of these tests, your TV rod (or TV cable) is adjusted correctly.
Capiche?
1 - 2 = 15 MPH
2 - 3 = 25 MPH
3 - 4 = 45 MPH
Capiche?
Thanks for all that. I guess Ill go buy a tachometer and see where shes at.
1 - 2 = 15 MPH
2 - 3 = 25 MPH
3 - 4 = 45 MPH
Capiche?
40-45MPH 3rd Gear and OD at 55MPH
For normal driving, those shift points sound about right. The AOD shifts into overdrive when you ease off the accelerator pedal at speeds over 45 MPH. So If you are driving normally in a 45 MPH speed zone, the AOD should shift into overdrive at about 45 MPH.
If it doesn't, or if it CLUNKS into overdrive, your TV pressure is too high.
